EGRC Solenoid valve
Old Jun 19, 2005 | 06:58 PM
Maximus_95's Avatar
EGRC Solenoid valve
Ok guys, Got CEL after fixing my fuel injector problem 0209. Then after i changed the fuel injector, i got another CEL 1005 (EGRC Solenoid valve) i could not find information on how to get this fixed.
Can anyone lead me to the right direction?
I need this fixed asap.
My car keeps stalling and i need to fix it so i can get to work. Please help. Thanx guys.
Old Jun 20, 2005 | 09:06 AM
Maximus_95's Avatar
BUMP! Cmon guys, someone out there must know how to get this fixed.
Old Jun 20, 2005 | 05:09 PM
VGinMIA's Avatar
I had this problem a few months ago. The EGRC valve is a small sensor located close to the throttle body. Its only function is to receive signals from the ECU which then tells the EGR valve when to open/close.
Note: a faulty EGRC will not cause your car to stall- at least not for me. If the sensor is faulty, it just means your EGR system isn't functioning properly.
Here is a link that may help:
http://forums.maxima.org/showthread.php?t=350528
I replaced mine for under $50 and the code went away. Now that it's stopped raining, I was able to snap some pictures for you...should help you locate the sensor. PM with your addy if you want the pics.
Old Jun 20, 2005 | 06:21 PM
Mishmosh's Avatar
Yeah, your emissions may go up (mainly NOx) but that should in no way impair performance. You need to look elsewhere for stalling issues ie. vacuum leak, etc. Pretty easy to test for the solenoid functionality.
Old Jun 20, 2005 | 06:31 PM
Maximus_95's Avatar
Geez, this is giving me a headache. I have had soo many problems in the past year. Im not so sure if the car is worth it anymore.
but what i remember most is that not stalling much, but more of a sudden loss of power when driving around then power comes back in a second. when coming to a stop, idle drops like its going to die.
but i was stalling most when my fuel injector was crapped out. I got it replaced and just got this new CODE.
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
homeofbacon
Sep 23, 2015 07:17 PM
tardrex
Sep 11, 2015 07:35 PM
