At start up...
Old Jun 20, 2005 | 10:26 AM
ikalinin's Avatar
At start up...
Quick q's guys! I noticed that everytime i start my car... the RPMs are at 1200 or soo... is that normal? its 85F outside and the car was parked for 5 hrs... i mean it doesn't stay that hight for long.. but i'd say in about 2 mins, it dropps to normal idle...
is this normal?
Old Jun 20, 2005 | 10:37 AM
NmexMAX's Avatar
dot dot dot ...
Normal .........
Old Jun 20, 2005 | 10:43 AM
Rob01ski
Yep totaly normal
Old Jun 20, 2005 | 11:57 AM
Anarchist's Avatar
if you're really that concerned, clean the throttle body. It'll take maybe an hour, and idle will be lower.
Old Jun 20, 2005 | 01:02 PM
LA02MAX's Avatar
i don't think it'll make much of a difference...if any, it will be so marginal that you won't be able to notice it by looking at the tach needle....1200 is about right because the engine is just trying to warm itself up...the operating temp. is higher than outdoor temperatures, so regardless of how hot it is outside, it will idle at ~1200 when started cold, although it does drop quicker when it's hotter outside...
Old Jun 20, 2005 | 01:07 PM
NmexMAX's Avatar
dot dot dot ...
Funny because when I clean mine, it actually goes higher at start-up ...
Old Jun 20, 2005 | 03:31 PM
ikalinin's Avatar
thanks
thanks guys! i appreciate the help and everything.. i figured it was fine, but i wanted to make sure!
thank you all!
Old Jun 21, 2005 | 09:59 AM
PTNR's Avatar
how about high idle when shutting down after driving for about an hour? 1200-1500. i get this all the time. normal?????????
Old Jun 21, 2005 | 10:30 AM
njmodi's Avatar
Do I get a tax break?
A higher idle after any cold start (1 hr or whatever) is normal. As the car warms up, you should notice the idle speed dropping, settling somewhere around 600-700 (depending on auto/spd).
Old Jun 21, 2005 | 11:09 AM
NewLoveI30's Avatar
After warm, my car idles at about 600. the RPMs are higher at cold start-up to get the correct oil pressure. (When the oil is cold the pressure is lower, so the engine compensates by boosting engine speed)
Old Jun 21, 2005 | 12:19 PM
Galo's Avatar
Maxima Pilot
Originally Posted by NewLoveI30
..... the RPMs are higher at cold start-up to get the correct oil pressure. (When the oil is cold the pressure is lower, so the engine compensates by boosting engine speed)
Ahhh...sorry to burst your bubble but it's exactly the opposite....cold temps = higher oil pressures.
The reasons Maxes -or any other computer-controlled car idle faster at start-up is to warm up the car faster, specially to 'light off' their catalytic converters faster, not because of oil pressure which comes up no more than two seconds (often much less) after a cold-soak start.
Old Jun 21, 2005 | 12:44 PM
NewLoveI30's Avatar
You are trying to tell me that higher temperatures are not associated with higher pressures? Where did you go to school? I think their physics program could use some help.
Also, many new cars (including ours) idle at very low speeds. If we idled at 500 RPM when the engine is cold (and pressure is low) there would not be sufficient lubrication. This in addition to warming up the engine more quickly is the reason for the higher RPMs at start up.
Old Jun 21, 2005 | 02:51 PM
paralyse's Avatar
I Miss My Maxima
NewLoveI30:
Your physics program ever hear of viscosity?
Old Jun 21, 2005 | 03:12 PM
NmexMAX's Avatar
dot dot dot ...
NewLove, give me that shovel before you get so deep you can't get out
Galo > j00
Old Jun 21, 2005 | 03:43 PM
LA02MAX's Avatar
Galo > j00
this looks like fun
Old Jun 21, 2005 | 05:01 PM
NewLoveI30's Avatar
Yes, I am quite aware of what viscosity is.
Still dont see why engine speed and the low viscosity of cold oil can't work together to acheve proper lubrication. But hey, I've been wrong before
Old Jun 21, 2005 | 06:58 PM
paralyse's Avatar
I Miss My Maxima
At cold oil temperatures the engine's oil pump must work harder to provide an equal volume of oil to the lubrication system. Therefore, oil pressure varies inversely with engine oil temperature. Imagine trying to drink water through a straw vs. trying to drink molasses -- you must exert a higher pressure (suction in this case) to move an equal volume of the substance through the straw in a given time frame.
Old (carbureted) cars idled high to warm up the engine because carburetors had no provisions for adjusting the air/fuel mixture to match engine temperatures other than the choke, and the jetting and enrichment circuits were designed for a warm engine.
Newer cars idle fast to warm up the engine to operating temperature, to lubricate the engine more efficiently, to recharge the battery slightly faster after the drain of the starter motor, and to get the precats hot for EPA cold-start emissions testing. Once it warms up and the thermostat opens the computer can switch its mode of operation to provide the optimal AFR. If you install an oil pressure gauge in your car you will notice that on cold start the pressure will jump from 0 to near the end of its range, then slowly come down as the engine warms up until it is running close to the low end of its range at idle with a warmed-up engine.
FYI -- I'm not disputing anything except your claim that oil pressure rises with oil temperature. You are correct that increased RPM at start-up contributes to improved lubrication.
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
