buying a 12w3 tomorrow, what box??
So i'm going to buy my 12w3 tomorrow
, should i build a ported or sealed box for this sub?? i listen to rap only when trying to show off,lol, but mainly rock, what do yall think???
Well, here is the sizes of the box you will need whether it is ported or sealed http://www.jlaudio.com/subwoofers/pd...PowerRange.pdf . Here was a discussion about which setup is for which http://forum.ecoustics.com/bbs/messages/4/4467.html . And if that isn't enough, here is a link to an owner's manual on the subwoofer http://www.jlaudio.com/subwoofers/pdfs/12W3v2_MAN.pdf . HAVE FUN!
I have that same sub, I built a ported box to the specs that are listed in the owners manual and I am very happy with the results. I listen to mostly rap, but the bass from this setup is still pretty tight and accurate.
port the box if you looking for a bit more spl. but ported box are less accurate. if you're going to listen mostly to rock, a sealed box will be your best bet, due to the great sq a sealed box can provide.
I think it will be a little punchier and more accurate in a sealed box but if you put it in a vented box and tune it low, it will still be very accurate (as long as it is tuned low) and a little louder than a sealed box.
Just my $0.02
Just my $0.02
well ya shouldn't have gotten rid of it
i was going to pic up the sub today with a sealed box but i didn't make it back to the shop in time, now i gotta hope i can make it after work tomorrow
The most important thing for you is to have good power....
I have a sealed box in my car and a ported in my girls car.....she has 300watts going to it and I have 400 watts going to mine.
Mine hits harder (punch) and are about the same with low end grunt like with rap etc....but mine does get the nod.....
Vent the trunk....the Maxima trunk is very tight.
Sealed will save you space and is usually easier to build.....
watt for watt the ported box will have a bit more SPL.....
Weigh your options....
--Jason
--Jason
how in the hell do you port a trunk?
oh will it make a difference if i get a sealed box and its not exactly what JL recomends? like will it hurt it any?
Always use JL's volume recommendations when possible. Dimensions doesn't matter...its the internal volume that does....
Originally Posted by Robert_J
Us the INTERNAL dimensions of the box to determine volume. Also, that's "net" volume. You need to account for the amount of air your sub (cone, frame and magnet) displace and any bracing inside the box.
-Robert
-Robert
Also JL's specs with the slot ported box account for the space taken up by the slot also.....
You can always call JL and speak with them directly.....
--Jason
Originally Posted by shoman94
Make an opening in the rear deck for example that allows air to pass thru.....
ok finally i have the subwoofer, the place i bought it wanted to charge me $70 for a sealed box and i laughed at him, my local one said $35, only problem is its not built to the sub, so, how much would it cost to build my own box and what all do i need to build it? i have the design for the box, just going with a sealed box right now
What power tools do you have access to? Do you know how to use them without cutting off any fingers?
I recently bought a Schosche sub box at Wal-Mart for $32. I went ahead and glued it together instead of using their gasket seals. In 45 minutes I had a 1.2cf sealed and carpeted box. I dropped an ED 12A.22 in it. Sounded really good in a friends truck powered by a JBL sub amp. I just need to get the amp installed in my old Maxima.
-Robert
-Robert
i have a drill, jigsaw, sawzall, just about anything i should need really, only thing i should have to worry about buying is the wood and glue and screws if i need thoughs, am i forgetting anything?
the recommended sealed enclosure is only .05 bigger than walmarts, doesn't walmarts come with wires and everything, is it a good quality board and stuff?? would .05 make a difference?
I may pick up the 10" version so I will have something for my Lambda Acoustic subs.
-Robert
When you wood glue it, it's a well built, carpeted generic box. Not a bad deal for under $40. I'm going to use it for a while because I have more important items to build. Finish a left, center and right speaker for the living room. Build two subs with Atlas 12" drivers for the living room. Finally, complete my theater room which includes re-painting (going from dark purple to dark blue), building all of the speakers (seven total), installing the subs (four 15's in an infinite baffle configuration), building the screen (between 100" and 110") and installing the projector (haven't decided on the model). All of this before college football season kicks off.
You may have different priorities and more time to build a custom box.
-Robert
-Robert
Stagnet04
Sep 14, 2015 11:28 PM
