tune up blues$$$$. i mean... help
Old Jun 21, 2005 | 04:35 PM
maximo-SE's Avatar
ive read a few threads in the past but i totally forgot what they said since its been more than half a year...
a few questions...
1)do anyone of you still use BG 44k or you can just use some other brand name fuel injector cleaner?
2)i guess i have to replace my auto transmission fluid, how many quarts should i buy and how many quarts do i put in?
3) what else besides those two and coolant flush do i have to replace.
(* note i cleaned my in cabin filter which is good for another 5000 miles i hope, changed wiper blades with PIAAs,and changed my oil.)
is there anything else im missing.
any help is appreciated, i couldnt find this in the stickies
Old Jun 21, 2005 | 05:51 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
a few questions...
1. I used it once and to me a total waste of money... use Seafoam instead
2. Look at my sig for a total flush step by step.
3. Power Steeering fluid.. same as tranny ATF
4. Brake fluid.... should be replaced.....
5. Wiper fluid... j/k
Good luck
Old Jun 21, 2005 | 06:06 PM
PearlWhtMaX2000's Avatar
i agree use seafoam through the Vaccume hose, and gas tank
Old Jun 21, 2005 | 06:08 PM
instil's Avatar
air filter.....maybe check the spark plugs. I actually saved Lontars writeup for the AT fluid flush a few weeks ago but havent done that yet. I didnt know it was that important to do the same with the power steering and brake fluid,guess i'll get on thast eventually
Old Jun 22, 2005 | 04:33 AM
maximo-SE's Avatar
i cant seem to find the seafoam products, can any of you provide me the full name of the seafoam product. pearlwhitemax... you mean i can just pour the seafoam into the gas tank right. i dont need to do anything correct?
Old Jun 22, 2005 | 12:45 PM
Digger01's Avatar
I two have been looking for the seafoam product with no luck, I have been to all the auto stores and even checked walmart....
Old Jun 22, 2005 | 07:25 PM
instil's Avatar
Foamtastic
Let there be Foam..... Rejoice
Old Jun 23, 2005 | 06:31 PM
maximo-SE's Avatar
so i just need to add one 16oz into your gas and you all set.
oh yeah thanks instil
Old Jun 24, 2005 | 12:19 AM
instil's Avatar
No problem....i just bought fuel injector cleaner last week and it didnt do ish. If you get that Sea Foam, or go a different route that works, PM me or post in this thread. If the sea foam product works ill get some. Bad enough i cant change my fuel filter, I'd at least like to have the fuel injectors clean
Old Jun 24, 2005 | 01:26 PM
jenk01SE's Avatar
NAPA also carries it in-store
Old Jun 24, 2005 | 01:29 PM
LA02MAX's Avatar
i always get mine at O'Rielly auto parts, but i've seen it at auto zone, checker, and napa as well....it works great! i can definitely tell that my idle and acceleration are both smoother....good luck!
Old Jun 24, 2005 | 04:04 PM
instil's Avatar
how often do you use it? i think i need to try it out at least
Old Jun 24, 2005 | 04:42 PM
SoonerFan's Avatar
Cletus
your owners manual has a list of everything you need to do
1. i use BG44K and yes it works
2. owners manual
Old Jun 24, 2005 | 04:59 PM
tony1208's Avatar
BG44K is good stuff
Old Jun 24, 2005 | 05:00 PM
Lontar1's Avatar
This will help you.....use it using the brake booster line... have fun
http://forums.maxima.org/showthread.php?t=346574
Old Jun 24, 2005 | 05:34 PM
IgS's Avatar
IgS
i put one can into my gas tank and half of another went into my oil... car seems to run much better..
Old Jun 24, 2005 | 05:53 PM
instil's Avatar
2. owners manual
owners manual advises you to wait too long (in my opinion) to check/replace many different things. As far as a listing of different things to be done, manual does list mostly everything, but i dont like the schedule it advises you to follow
Old Jun 24, 2005 | 07:57 PM
SoonerFan's Avatar
Cletus
well the schedule is for a normal person driving it...not one of us
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
