ECU code 0302 ?
Old May 19, 2001 | 04:52 PM
zaebis
I have EGR code 0302 (EGR System) . Does anybody know what might cause one?
Thanx
Old May 19, 2001 | 06:41 PM
Daniel B. Martin's Avatar
DTC 0302
Originally posted by zaebis
I have EGR code 0302 (EGR System) . ..
You did not specify the model year of your car. This information comes from the '99 Maxima factory service manual.
Diagnostic Trouble code 0302 points to a problem with the Exhaust Gas Recirculation system. The malfunction is detected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR. Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
Old May 20, 2001 | 06:35 PM
zaebis
Re: DTC 0302
2 1
2 3
5 4
5 6
Thanks I will try that, but also I reset the "check engine" light and havnt done anything else. The light does not come on anymore (at least for now). Does it mean that it will not come on with this code (0302) even if EGR system continues to malfunction or will it come on as soon as a malfunction is registered in EGR system?
Old May 20, 2001 | 07:15 PM
Amnesia
When the Engine Control Module is reset it experiences complete amnesia about anything which has happened in the past. It is like a newborn ECM. It will turn on the Check Engine Light as soon as any malfunction is detected, and store the appropriate Diagnostic Trouble Codes for subsequent retrieval.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
