Anyone knows what goes HERE?
i will try to look at my fuse box tomorrow morning.
as for the second pic, that looks like the cornering lights? is that at the bottom, front end of the car? The fog lights are attached to the headlights.
Originally Posted by SoufSidah09
Wow I got it all wrong then..I thought what you marked as fogs were the high beams/DRL and on the bumper cover was fogs as the bulbs seem to be clear...
This is the fuse box under the hood...
I'm thinking I'm missing a relay...
Ohh..and what is it for..
Originally Posted by Tek-Niq
nope.. our high and low beam are in the same assembly.. one bulb two functions..
As far as I knew you needed a sperate bulb/projector for high...
nope. the projector is dual beam. click on the high beam and stick your head out the window, you should hear a click. its the shutter thats opening to allow more light(the high beam) to happen.
theres only 1 hid bulb and its a single filament.
I have the HID setup, so does the Xenon bulb operate at low & high beam?
well what I meant to say is that the light only burns one color, not like a 3157 bulb that switches from low to high...yes I stand corrected, hid bulbs do not have filaments, sorry for the confusion!
I'm glad I have the Max guru's in this thread! Thanks PaL
I've got another question...04SL; I'm not sure where this wire goes...it's behind the drivers side headlight, looks like a horn maybe? I'm not sure if the Max has a horn on the drivers side? I followed the black cable to the wire bundle and it's actually a green wire... any ideas?
