I tested 0-60 with my SC I30 today!! {G-Tech}
My I30 finally is back and my new Clutch has been broken in so I decided to take a few 0-60MPH runs today with my G-Tech pro. I got the following times from 0-60mph, 6.22,6.10,6.05 and 5.44!! It took a few try's to get my Launch down with the new Clutch and all, the first 3 runs I was just pealing out most of the way, but on the last{5.44} run I took it real easy and made sure I did not peal out too much. BTW these #'s reflect my car with about 50 Lb's of stuff{Basketball, box etc.} and my spare tire and a full tank of gas. Later on tonight I will take out the stuff and spare tire and try a few more times, I am preatty sure I will see some 5.1-5.3 runs later on tonight.
Originally posted by emax95
My I30 finally is back and my new Clutch has been broken in so I decided to take a few 0-60MPH runs today with my G-Tech pro. I got the following times from 0-60mph, 6.22,6.10,6.05 and 5.44!! It took a few try's to get my Launch down with the new Clutch and all, the first 3 runs I was just pealing out most of the way, but on the last{5.44} run I took it real easy and made sure I did not peal out too much. BTW these #'s reflect my car with about 50 Lb's of stuff{Basketball, box etc.} and my spare tire etc. Later on tonight I will take out the stuff and spare tire and try a few more times, I am preatty sure I will see some 5.1-5.3 runs later on tonight.
Originally posted by BottleFedMax
Hey also if you can try to get some #'s for the 1/4 mile. I'm real curious as to what you're running. Thanks and keep us posted.
Maybe tonight I will try the 1/4 mile, I am still real scared about doing a fast 3-4 shift after what happened a few weeks ago.
I don't blame you it's gotta be scary. But try holding the shifter with your thumbs down with the pinky up sort of like a upside down grip if you would. That should help in keeping the shifter from going into 2nd because with the upside down grip your arms will be positioned to pull away from 2nd gear and into forth. Hope that makes sense..Good Luck!
learn how to shift
Yep, thats what I usually do but I did it the wrong way when I busted my car, I think I actaully did it almost out of pure stupidaty becuase I have just about never done a fast 3-4 shift before, when ever I shift fast it's from 1-3 not 4-5, so I think what happened was I was actually aiming for 2nd becuase thats were I usually shift fast from up top{1 and 3}.
enjoy
BTW, very nice time. Did you check horse power?
Originally posted by LoveSick
Proud of you man, I once had a GTch Pro from a friend. But I couldn't get 0-60 working. How'd you do it? All I could do is 1/4.....
Kinda OT, but...
anyone seen the new Blitz Power Meter(in car dyno)? I think it costs a little more than the G-tech, but after entering the weight properly it's readings were only .4 off of the actual Dynojet results. plus its got some other goodies including bargraph and line graph readouts(like a real Dynojet sheet), peak horsepower and the other usuals like 0-60 and 1/4th mile.....plus wouldn't it be more accurate since it's tapped directly into the speed sensor wires, etc. at the ECU?
and hey its another cool gadget to add onto the ride!
Re: Kinda OT, but...
Thanks!
Re: Re: Kinda OT, but...
That's wicked! Anyone know where to get it? Wheres the info?
Thanks!
Thanks!
Re: Re: Re: Kinda OT, but...
Dumb question:
where do you get you car weight to enter into the GTECH?
The curb weight that is printed on my door says 4400 pounds(approximation) and there was a post a here where some peple had their cars weighed and came out weighing 3000-3300 pounds.
So which weight do you use the scale or curb weight?
Re: Re: Re: Re: Kinda OT, but...
Originally posted by nm
Dumb question:
Dumb question:
New Test results, I drove out to a huge straight away and decided to do one 1/4 mile run, I got a 14.25 @ 103.4 MPH. I got a bad launch as usual and had a 0-60 time around 6.1 on that run. Judging by my trap speed my car could easaly be in the low 13's with a good launch as specialy if I had some better tires{Mine are bald}. Anyways no more testing because I don't want anything to break on my car.
Dumb question:
Dumb question:
Tarheelmax: Thanks for the info!
Re: Re: Re: Re: Re: Kinda OT, but...
I know hom much my car ways from info from Infiniti, my car weighed in at 3151Lb's. I know a 95 Maxima SE weights 3018lb's{according to MT.
Dave
Re: Re: Re: Re: Re: Re: Kinda OT, but...
Originally posted by Dave B
You need to take to the track so you can see what you are really doing. I don't trust G-Techs much because it says I'm running 14.3-14.4s@98mph.....consistently. Don't forget that trap speed is not the true "track" trap speed. The G-Tech will always read 2-5mph higher (depending on the power of your car) than a tracks timing equipment. Why? Because the track averages you mph over the last 60'.
Dave
Dave
Yeah, my 95 max ran a 15.28@ the same spot and the trap speed was like 94.8? Or something like that. Anyways I know I could do a lot betterwith my I30 if I got a good launch and actually tried to shift quickly. I don't think I am going to bother going to the track becuase I decided that I wan't to take it real easy on my car from now on, this has got to last me
. BTW Thanks for the input Dave.
Re: Re: Re: Re: Re: Re: Re: Kinda OT, but...
Thanks for the input Dave,
Dave
Dumb question:
Dumb question:
By chance do you know....
3rd gen GXE(VG) weight??
Originally posted by medicsonic
The weight on the door sticker is the absolute maximum weight the car is safely designed to carry around, including gas, passengers and luggage. NO Maxima weighs 4000 lbs. Your stock weight is about 2950 with a bare bones GXE, and runs to about 3150 for a GLE. (NOTE: These numbers are for the 4th Gens, the 5th Gens weigh about 150 lbs. more across the board).
I have weighed my car two times at this truck weigh station on the free way when it is closed. Somehow they leave the computers on so I just park on the scale and look in the window to see my weight. Both times it was with a full tank. The first time I had my car in racing trim, with no pass. seat or back seat, or anything in the trunk. I got 3140 w/o me. Second time I had all my junk in, speaker box, tools etc. and weighed 3320.....
Hmmmm.....
My Gtechs been all jacked up lately. I left it in the box for about 8 months, and just recently dusted it off. I tried it a few weeks ago, said the max was making 3-400 hp, and when the car shifted, it jumped up around 500. YES, I know how to use it, I was on a level surface and all, it's just jacked up. I did the 0-60, it stopped clocking at like 40mph and posted the speed, then started flashing waiting for me to do the 60-0. Too bad it's not under warrenty anymore.
Re: Hmmmm.....
Emax, love that photo of your car! Looking great! Where did you get that grill? Wonder if they have one for the 5th gen I30? Did you add the Infiniti logo to the grill?
I'm going to need to post some new photos of my tint job ans suspension mods, to see if mine looks half as cool as yours! I'd love to SC mine, but playing with the ideas of turbo or NOS now. Plus, I think I'm not going to buy anything from stillen from all the stories I've heard.
Like others have said, you MUST take it to the track now. No point in having all that stuff on the car if you want to drive like granny
If you do, sell it to me and get a Camary!
The weight shown on the door is GVW (gross vehicle weight). That is the max. recommended loading of the car...full passenger load, full fuel tank, etc. It's way more than the actual weight of the car unloaded. The weight listed by Nissan for 4th gens is like 3000 for a 5spd, 3100 for an auto, and for 5th gen about 150-200 more than the 4th gens. Roughly (within ~50 lbs or so).
Dumb question:
Dumb question:
Waaaay OT...
Oh, and Emax. You know your hp, tq, 0-60, 1/4, etc will improve if you get rid of that 50lb wheel/tire combo.
It's still amazing that your car can pull a 5.4 with them on. Keep up the good work!
Re: Emax
I'm curious how you launched it on that 5.4
did you slip the clutch for a bit, then drop it or slowly release it?
on the 3-4 shift, just put 2 or 3 fingers on the back of the shift **** and pull downwards towards you. Your thumb can be on the left side. This is a really safe method. Notice how no part of your hand is on the right side of the ****? so your shifter CANNOT go into 2nd.
I do this all the time cuz the Celica is getting a lot of attention due to all the driver misshifts from 3 to 2 (due the tight 6 spd gates)
WOW
Those are some good times but i would have expected faster. The 5.44 is good but like you said 5.1 is where you should be, you should really go to the track. Give me a couple weeks to get my 300ZX TT 5-spd and we'll give it a go, but i think i might need to get the stillen chip, hehe. get some new tires too.
Re: Re: Emax
When I got my 5.44 time I played the clutch just right and launched so that I got a small amount of wheels spin and then just took it up to 35mph just gentley enough so I would not get wheel hop or do a huge burnout, then I did a nice smooth Shift into 2nd and just floored it and bamb 5.44! I usually get around 5.7-5.9 because it is really hard to get just the right launch down.
DMBMax, I was hopeing to get maybe a 5.1 but my car is really traction limeted, another words I have a lot more power to offer off the line but my tires just can't gripp the pavement well enough. I am possitive if I put some nice fat slicks on my car a 0-60 time of 5.1 would be easaly reached. Even with out the slicks I know I can do a little better becuase all my times were with a full tank of gas and my front windows down and some junk in my car.
When my gas take is almost empty I will give it a few more try's.
sounds nice
You still should think about getting some new tires even if they aren't slicks you said the ones you have now are bald. You should run a 5.1 with new tires, not slicks and empty tank. Why do you always have the windows down? everytime you do a run your like i left the windows down, hehe. nice runs though.
Re: Re: Re: Emax
Thanks for the info.
Re: sounds nice
It does not make that big a difference from 0-60.
Re: Re: Re: Re: Emax
damn man, that's crazy! You can't even gas it in first cuz you'll spin your tires! ahah I can't even imagine that much power!
Re: Re: Re: Re: Re: Emax
Originally posted by deezo
Man, you have to ride in the car, its fast as hell.
