Battery and Brake light came on while car was driving
Old Jul 7, 2005 | 04:52 PM
lhercules's Avatar
Battery and Brake light came on while car was driving. What does that mean? I hope it is not my alternator going? Help me
Old Jul 7, 2005 | 04:57 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
same thing happened to me about 9 months ago. alternator. have it tested to confirm but the combination of those lights typically leads to that. at first i only saw the brake light and could not figure out why it lit when the parking brake was down and it had plenty of fluid.
Old Jul 7, 2005 | 05:07 PM
lhercules's Avatar
How much did it cost? So I guess it is the alternator
Old Jul 7, 2005 | 05:18 PM
Barc's Avatar
Its the alternator or something else in the charging system. Had it happen to me on a previous car and the battery cable had come almost off and was not making good contact... Check the very obvious first.
Old Jul 7, 2005 | 05:22 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
alternator going, $230.00 in autozone
Old Jul 7, 2005 | 06:14 PM
kpr10is's Avatar
+1 to sloppymax, just happened to my moms 00 SE. Autoway Nissan charged her in the 500 range for the alternator installed. I say get one from Dave B, find/pay a local .org'er to help you do it, and save yourself a couple hundred bucks
Old Jul 7, 2005 | 06:36 PM
chrisexv6's Avatar
I agree with Barc. Something similar happened in my Accord, SRS light would come on at certain RPMs, flicker a bit and then go off.
Assumed battery and/or alternator. Dealer checked out alternator and it was fine. I purchased a replacement battery and went to install it, and thats when I found the positive battery cable was not even hand tight. Go figure, the dealer missed it too.
Check your connections, then look further.
-Chris
Old Jul 7, 2005 | 06:47 PM
sloppymax's Avatar
i got mine at a local shop that just does alternators and starters. got the reman for well under 200 and sr installed it for me.
Old Jul 8, 2005 | 12:31 AM
lhercules's Avatar
So I take it that the warranty does not cover that. What good is that extended warranty?
Old Jul 8, 2005 | 12:38 AM
E55AMG2's Avatar
Wat
It might, no harm in trying.
Old Jul 8, 2005 | 05:42 AM
sloppymax's Avatar
it might have if i did not have an odyssey 15lbs battery in there. if my oem battery was still good, i would have popped it in there and taken it in. i needed a quick fix in this instance and the my extended warranty has already paid for itself many times over.
Old Jul 12, 2005 | 06:25 AM
piglit's Avatar
I have the same light combo happening- put a volt meter on the sys and readings were all OK...
I did notice that it seems to occur when motor is at hi-temp and I am coming off the hiway. Perhaps (mine, at least) is a belt issue w/ cooling/ alt.
-piga
Old Jul 12, 2005 | 06:27 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
its your alternator
Old Jul 12, 2005 | 07:48 AM
Kevlo911's Avatar
Kevlo for President
Doesnt a 95-99 Alternator fit? If so, why not get that, it will have 125amps compared to 100-110 of 5th gens.
Old Jul 12, 2005 | 08:14 AM
Maxrider24/7's Avatar
Sounds like the alternator but test the alternator at a shop that has a tester that way you know sure that is the problem
Lakersallday24
Jun 16, 2019 01:35 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
Trin1j23
Aug 12, 2015 08:31 PM
Superbform
Aug 11, 2015 08:10 PM
