Loud noise coming from the front of the car
Old Jul 11, 2005 | 05:10 AM
nismax96's Avatar
This weekend I started hearing a thump thump noise when I was driving. It would stop when I would hit the brakes. Could it be time for brakes or could it be something else?
Old Jul 11, 2005 | 05:16 AM
instil's Avatar
is the noise coming from the wheel? is it always thumping,or only when you hit bumps? did the noise stop when you hit the brakes because the brake pads were holding the thumping part steady, or because you weren't moving anymore?
Old Jul 11, 2005 | 05:18 AM
instil's Avatar
maybe theres a philly thug stuck under your car. you mightve drove off while he was under there trying to ****** off your HID's
Old Jul 11, 2005 | 05:25 AM
Maxrider24/7's Avatar
HA HA thats funny
Old Jul 11, 2005 | 05:28 AM
nismax96's Avatar
Intil - The noise is coming from the wheels and I hear the thumping when the car is moving. it stops when i apply the brakes.
Old Jul 11, 2005 | 05:33 AM
instil's Avatar
from both wheels? im guessing its just one side right? im not trying to be a d%ck, im just asking becasue ive had many wheel noises in my two years with a maxima
Old Jul 11, 2005 | 05:34 AM
nismax96's Avatar
Its coming from the driverside front wheel. I even feel the thumping in the floor of the car.
Craig_0530's Avatar
I choose not to comment.
Does the noise happen when you accelerate? What about when you're coasting? That has happened to me. It was my wheel bearings.
Old Jul 11, 2005 | 05:39 AM
nismax96's Avatar
Craig - yes it happens when I accelerate. I also hear it at coasting speed.
I shouldn't need wheel bearings yet. I just bought the car in December.
instil's Avatar
you should take the wheel off and inspect things. you probably bent something hitting a pothole in the city
Old Jul 11, 2005 | 05:46 AM
nismax96's Avatar
Instil - You are probably right with all of the potholes we have.
Thanks for the info.
Old Jul 11, 2005 | 05:53 AM
instil's Avatar
the fact that it stops when you brake.....it confuses me haha. bring it somewhere to get it diagnosed, then post on here to see if its something you can easily and cheaply do yourself. thats how ive been fixing my car recently when i cant determine what the problem is
Old Jul 11, 2005 | 06:00 AM
Craig_0530's Avatar
The symptoms that you have given are the same ones that I had six months ago. I couldn't believe that my wheel bearing went bad that soon. Good luck.
Old Jul 11, 2005 | 06:01 AM
nismax96's Avatar
I will have it checked tomorrow. I'll post when its done.
Old Jul 11, 2005 | 06:19 AM
instil's Avatar
you aint gotta liiiiiiiiiiiiie craig
Old Jul 11, 2005 | 08:19 AM
wngan9447's Avatar
Chicken Feet Croo!
Loose caliper.....have you have your brakes worked on recently? Just check and make sure it's tightened.
Old Jul 11, 2005 | 10:00 AM
Bensmax00's Avatar
if it was a loose caliper then it would make noise when you apply the brakes--we had someone go to Midas to get their brakes done and the customer came to the dealer for a noise(thump) when brakes applied--found that they left both bolts on the right loose and they both fell out.
Old Jul 11, 2005 | 10:07 AM
wngan9447's Avatar
Chicken Feet Croo!
I had one loose before.. the top bolt was secure and bottom wasn't... it kept banging against the rim and it stopped when the brakes was applied
get my drift?
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
follyburr
Aug 7, 2015 09:50 PM
BassAddictJ
Aug 4, 2015 11:38 AM
Jcof88
Aug 3, 2015 10:43 PM
