Rusting already :mad:
I ahve an 02 Maxima 43k miles on it. i bought it a few months ago. I have notivced a few areas where there is noticable rust already starting to come through the pain. mianly under the drivers door, its bubbling the paint, and the paint has a rusty clored tint to it. also the drivers rear wheelwell, the thin lip on the front side has the rusty color too it. what can i do before this gets worse? keep in mind, the wheelwell rust is in a noticable spot. also, anyone else experiencing this?>
Sand down and paint over it, this is not good. I would have the car inspected by someone. Infact, you should still have the "rust" warrenty from Nissan. Go raise hell at the dealership.
what do you mean by ^^that?? the entire front bumper assembly has no metallic parts to it therefore it wouldn't rust....do you mean the front of the hood where it meets the bumper on each end?
There's a seven year corrosion warranty. However, it's limited. It does not cover things like rusting due to paint chips, scratches etc. Basically if the rust is starting on the surface you are out of luck. If, however, the rust is coming up from underneath then you may have a valid claim. IMHO experience though, the dealership will try and screw you over and claim that the rusting you are seeing is not covered by the warranty. If you are sure that it should be, be firm and calm about it. Make the technician go over the car with you explaining exactly why it isn't covered by the warranty.
oh oh..I know the answer the dealership will give...
1) It is caused by rocks flying from the tires and hitting the wheel well.
2) Caused by brake dust..
Either way you are screwed...they wont cover it..I have the same issue and they wont do crap.
every car i've owned always had a small rust spot here and there and the max is no different. my 02 had a few spots and my 03 has a few on the edge of the hood....i just live with it....
He says it comming from underneith the paint. That means the paint has not been chipped yet.How many of you guys have ever tried to use the corrosion warrenty? Every dealer is not the same. And if the dealer says no, you can always call 1800Nissan1 and they will help you out.
I don't see why you wouldn't put in the effort to go to the dealer (or perhaps every dealer in the nearby area) and try get this fixed under the corrosion warranty. The worst answer is "no". It doesn't cost you anything (other than fuel and time), but if one dealer agrees to do the work under warranty, you've just saved yourself some $$. Doesn't make any sense to give up without even asking a dealer or escalating it up to Nissan corp.
but this rust warrenty is something real? i dont wanna go in there and look like an *** when i ask about a rust warrenty
Rust or Corrosion Warranty: This warranty covers the vehicle's sheet metal, and protects you from rust and corrosion that are severe enough to cause a hole - surface rust is not covered.
here u go. first is the rear wheel well. 2nd is under the drivers door. about how much am i looking at to get this fixed if its not covered, which i doubt it will be
http://www.ihostphotos.com/show.php?id=83745
http://www.ihostphotos.com/show.php?id=83746
The second one looks bad... I'd get that fixed ASAP - with or without warranty coverage.
When I had surface rust, I took it to the dealer (Canadian) and they said two reasons for no coverage: it was surface rust (on my roof) from stone chips and warranty is only 3 years 60,000 km... I was at 4 yrs and 66,000 km... I ended up paying to get it done...
my father had a 96 altima a while ago, and it had a rust spot where the rear tire well met the bottom sheetmetal. he had it repaired, but rust spot came back fast. they have to cut out a large chunk of metal that's rusted, and replace it. just sanding and repaininting does not do anything. anyway, even having this done, the rust came back. i think you would have to replace the whole bottom piece to get it done right, not just cut this rusted metal out and weld new metal on. since this is really close to the road, paint probably chipped off, and it started rusting the metal. good luck at the dealer.
i had the same problem in the wheel well last year (before winter, with all the snow and salt on the road)... i sanded it down, covered up the surrounding area with newspaper, then sprayed black rubberized paint on it and it has been ok so far.
Preventive maintenace is a must while unclogging window drains (should be done every 6 months).
I went to the dealer 5 months before my "rust warrenty" expired. I had rust on the pillars or both rear windows (they said it wasn't covered because it wasn't the sheet metal) and on the lip of my trunk which had been bleeding rust on my bumper so now my bumper is "rusted". They stated the rust hasn't perforated so it's not covered. Horsessh@t...now the paint is bubbling at my rear trunk lock just waiting to burst a rust baby.
RealityCheck
Oct 2, 2015 06:34 PM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
