2001 AC drain and Refill procedues and tools needed
umm, you don't drain it and refill it like engine oil. R134 is the coolant and is a gas at STP and liquid when pressurized or when it drops below a certain temp.
go here to learn how an A/C (or refridgerator) works
http://home.howstuffworks.com/ac.htm
This coolant also contains a lubricant that lubricates the a/c compressor. There is no maintainance schedule for the A/C. The coolant needs to be in a certain pressure range to operate properly. If the pressure is too low, than you will have reduced performance. You can buy the cans of R134 at any auto parts store as well as the pressure gauge.
I was thinking that mine needs a recharge and someone at work said that there must be a leak. I don't think that there is a leak just after 4 years it needs some more. He said that the coolant has no place to go and therefore you it could only have a leak, if I need more. Is this true or over time does the system need a recharge?
There's some bottles of the coolant that has some special dye in it that helps you detect leaks. I believe you need to have a black light to detect the residue that it leaves.
Rubber seals tend to dry up and crack over time and begin to leak coolant. I doubt that 4 years would be enough time to cause any significant leak. Nothing seals 100% and it will lose pressure over time just like tires, even if the seals aren't bad. Some of the places like jiffy lube will read the pressure and tell you if you need a recharge or not.
Alternatively, you could buy one of those refill cans with a gauge already built into it at autozone for $10-$20.
Having said that, my sister has a 92 Corolla and has never had the A/C recharged and it still blows cold air.
It always takes a few minutes to start blowing cold air, even on a brand new car.
Check the tension of the compresser belt. Check the pressure.
The FSM has a table of what the temperature of the air should be at various ambient temperatures and humidities.
At a 95deg air intake temp in recirc...
50-60% humidity 64-70deg
60-70% 70-77deg
60-70% 70-77deg
Originally Posted by siren001
Does anyone know how to properly drain and refill the AC for a 2001?
Any Pictures or how to's?
What tools are needed?
How long does it take, est, time?
60-70% 70-77deg
60-70% 70-77deg
hey man those numbers are a little high should be a little lower and measured with outside temp--cuz air intake temp is going to be hotter than 95 degrees in summer time--I was looking at consult on mine today and it was only 90 degrees outside but intake air temp was at like 120 degrees---usually on a 95 degree day you can get the a/c to blow around 50 degrees mine blows at 45-49
When I say "intake" temperature, I'm not talking about the intake where the MAF and TB is, I'm talking about the intake for the blower, the ventilation system.
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
District
Aug 15, 2015 08:23 PM
