Uh-oh, No AC. help please
Old Jul 16, 2005 | 01:53 PM
NCSU_MAX's Avatar
Maximoneypit
so the fan is not working but im getting all the lights on the console like theres still power. My friend thinks its the fan fuse within the console. Any advice? thank guys.
Old Jul 16, 2005 | 02:03 PM
PandaXpress's Avatar
try the fuse box on the driver side under the hood...i think there is an AC fuse..check that..then check the fuse ibox inside the car for ELEC COMPONENTS to make sure that all of the electrical components are working
Old Jul 16, 2005 | 02:12 PM
zad1
its the ac resistor thingy its under the pass. side
Old Jul 16, 2005 | 04:33 PM
NCSU_MAX's Avatar
Maximoneypit
where at?
10 chars
Old Jul 16, 2005 | 08:31 PM
zad1
its under the dash on the pass. side you'll have to look for it 2 screws hold it in.
Old Jul 16, 2005 | 08:41 PM
sunten1
Check your coolant levels, it happened in my mommys van...and she went to the dealer to have them fill up her coolant for 150 bucks...
Old Jul 17, 2005 | 06:25 AM
NCSU_MAX's Avatar
Maximoneypit
is it a harness or a box or...? also, closer to the center console or the passenger side door?
Old Jul 17, 2005 | 07:47 AM
zad1
yes a harness goes into it its closer to the door
Old Jul 17, 2005 | 10:07 AM
NCSU_MAX's Avatar
Maximoneypit
hmm, the only harness i see under the passenger side is this one and it looks like it goes to the passenger door electronics?
only other wires i see are these, by the center console.
Old Jul 17, 2005 | 10:43 AM
zad1
thats it there is 2 screws that hold it in
Old Jul 17, 2005 | 01:37 PM
NCSU_MAX's Avatar
Maximoneypit
ok cool, what do i do w/ it? (sorry im very much an electronic noob)
Old Jul 18, 2005 | 08:41 AM
diy_dreamer's Avatar
Buy a haynes manual, it explains how to check it.
Old Jul 18, 2005 | 11:19 AM
zad1
you need to replace it same thing happened to me and i replaced mine and everything worked fine after
Old Jul 18, 2005 | 05:13 PM
bloomer65's Avatar
I have a similar problem, but my fan only works when on high (4). I pulled the assembly, but the fan still works - do I have the same problem??
Old Jul 18, 2005 | 05:23 PM
zad1
yes if your fan only works on 4 then you need to replace this part
Old Jul 18, 2005 | 06:12 PM
XtinctWS6's Avatar
could this have something to do with frion(spelling)?
Old Jul 18, 2005 | 07:16 PM
NCSU_MAX's Avatar
Maximoneypit
can i get this at like an autozone or do i have to get it from the dealership?
Old Jul 19, 2005 | 12:29 PM
NCSU_MAX's Avatar
Maximoneypit
bump...................
aw11power
Oct 10, 2021 04:57 AM
pears
Sep 18, 2015 05:25 AM
Courtneysnow
Sep 4, 2015 05:10 PM
roastduck88
Jul 27, 2006 09:39 AM
