once again my question that has stumped all orgers...
My hazard light switch does not work... i looked behind the console and the button is plugged in i just dont understand why it doesnt work...
My turn signals all work perfect and it seems my max is cursed with electrical issues becuase not only do the hazards not work but the passenger doos speaker, tweeter, and door light are all out i took door panel apart and everything is plugged in and fine there too whats going on??????
Can anyone help me with this??
Well, it's either a fuse or a short. Turning bulbs can work fine but they won't work when you turn on the hazards cause they have an independant circuit. I read your other thread about this and I saw no mention of checking fuses. About the speakers, when did they blow, what were you doing during the time they blew?
Doesn't the hazards have a relay?
About the blown speakers i don't have a clue.... mine were out on only one side as well. I replaced it with a new speaker and still got nothing.
I have no clue when it comes to electircal wiring.
The only think that i could possibly think would be like to do a power flow test. LIke get a wiring diagram of the hazard/turn signal circuits. Do u have power going TO the switch? Do u have power to the bulb? do u have flow to ground?
I do know that if my haz switch is not hooked up, some other lights won't work. But it shouldn't affect the stereo stuff. The reason why it's stumped .org is because your descriptions are WAY to vague. You know how hard it is to diagnosis crap over the net? Without seeing the car and w/o knowing what you did before??
How about some simple tests with the volt/ohm meter to confirm you are actually getting POWER to these items?? And live Dave said, check all fuses first.
ok, when u push the hazard button, does ur turn indicators flash? (in your dash)
does the light behind your button work? (headlights need to be on)
Did u mess with your LED's behind the climate control?
Could be a short, could be a broken button , could be a busted fuse
id check if there was any power running through the switch when the circuit is closed (switch on).
If no power, perhaps the circuit board is damaged, or the wire for this hazard light that runs to the board is damaged. Check for power BEFORE the board (no idea what wire at this point as my dash is in the car, and im not taking it out) and after the board (before the switch)
Temporary fix (signal left then right really fast)
ok just checked it out there is no light coming from either the hazard light button or the rear defrost button when the headlights are on no more glow behond these buttons the clock works though. and when i push the rear defrost button it lights the orange led and works???? i dont understand
also still no solution for the right door speaker, tweeter, or door light??
oh and no i have never tried any LED mods. yet...
dave can you draw me up diagram on which would be the relay for the speakers and hazard console maybe since you are so good at this you can show me which ones to check and how to check them i do own a voltmeter and my stepfather has all the other meters so cmon dave fill me in with your knowledge
Are you being serious or a ***** again? The tone of that posts seems a bit sarcastic.
Why would I need to draw anything? Every relay and fuse box has the component listed on the bottom of it. If you have a multimeter, just set it for continuity and check it across each fuse/relay.
Hey check the fuse box in the engine bay on the right hand side. And look for one marked ....crap I cant remember. But I will look when I go home. And let you know cause I haev had a similar problem, that and check the fuse under the dash on the right side. You might have to check every single one but it might be that too.
once I had a problem with my wipers. They stopped working in the middle of a hailstorm and later on i had to drive home in torrential rain. It was a real bichh. I checked everything ... took out the steering wheel column, the switch, the relays in the engine bay, the fuses, you name it.
in the end, a mechanic friend found a "false contact" in the driver side fuse box. I mean, that thing drove me crazy, not to mention how important wipers really are. I know this is not your problem, but you could be having a similar issue
more nyc guys i see! register on nycmaximas.org
ok enough with the advertisement...
im also interested so free bump, my hazard button and everything works fine except the light on my hazard button...i have almost never seen that trianle lit up since i bought the car...but the defrost one works fine...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
