Define some acronyms for a noob ;)
Ok, I figured out:
FSB : Front Strut Bar
RSB : Rear Strut Bar
HID: the nice lights available from 5th gen on
N/A : naturally aspirated = no NOS/turbo/super
MAF: mass air flow sensor
ECU: engine control unit
what do the following mean:
AE: ?
MEVI:?
feel free to add to this list.. maybe we could make it a sticky if it gets good enough.
AE: ?
MEVI:?
Originally Posted by godlyone
thanks.. if possible add some more commonly used acronyms..
what is a header?
what is a header?
the exaust manifold isn't in the picture, but is that plus the y pipe together..
AC= Air Conditioner
AWD= All Wheel Drive
MPG= Miles per gallon
MPH= Miles per hour
RWD= Rear Wheel Drive
WOT= Wide open throttle
ABS= Anti-lock braking system
A/F= Air fuel ratio
ATC= Automatic temp. control
DOHC= Dual overhead cam
MPH= Miles per hour
A/F= Air fuel ratio
those are all acronyms....wouldn't an abbreviation be like temp for temperature??
Originally Posted by TXT-1
And it's not acronym. They are abbreviations.
An acronym would be something like this:
NISSAN= Nasty Import Sucks Savings Away to Nippon
TB= Throttle body
IACV = idle air control valve
PCV = positive crankcase vent (or valve)
CAT = catolitic converter ( I know I spelled that wrong)
SE = Sport Edition
CEL = check engine light
ABS = antilock brake system
HID = High intensity discharge
PSI= pound per square inch
SAFC = super air fuel controller
VVT - variable valve timing
VVT-i = variable valve timing (inteligent . . . damn toyotas)
SE = Sport Edition
Originally Posted by MDeezy
TB= Throttle body
PCV = positive crankcase ventilation
CAT = catalytic converter ( I know I spelled that wrong)
SE = Sport Edition
SAFC = super air fuel CONVERTER at least that's what it says on the body of the one I was using
SE = Sport Edition
Thanks 2 MaXiMuS 4
I don't find anything wrong with this thread...how are you suppossed to find out what some of these acronyms stand for unless you ask? Especially if you're not mechanically knowledgeable (like me). I think it would be a good idea to have a sticky with the meanings of all the acronyms...or add it to the FAQ's. If you think this is a dumb thread then there's no point posting in it.
Originally Posted by gtr_rider
Originally Posted by Northern Maxima
Thanks 2 MaXiMuS 4
was in the supercharged forums earlier...what does FI stand for?
also...noob question: what does OG stand for?
BTW, that FAQ is insufficient, I think a complete list of acronyms for new members is a great idea
https://maxima.org/faq-1-General.html#2 - updated
Originally Posted by FAQ's
ECU = Supercharger
