Changing headlight Assembly
Over the weekend someone smashed in both of my headlights. Im not sure what night it was, or where it happened, or who did it. so needless to say im pretty mad.
After calling almost every junkyard in the tri county area I could only find the right headlight (Witch was suposibly aftermarket) for $140.
started calling parts stores and eventialy I found both of them for $160 after tax. got them today and am having problems getting them in.
does anyone know how to do this?
I can get all ot the bolts out exept the 2 on the outside, where somehow you either have to take off the fender or cornering light. But I cant figure out how to get the cornering light out without taking out the headdlight.
im probably going at this all wrong so if anyone can correct me it would be greatly apreciated.
By the way:
1996 maxima SE
Thanks for any help
By the way:
1996 maxima SE
Thanks for any help
Slip a flat head screwdriver in the little space between the headlight and corner light and pry the corner light out. It's really stuck in there good, so don't be afraid to use some force. Just when you feel like you're going to break it, it will magically pop out.
Good luck!
Good luck!
If it's the same as the 1997...there is a small black latch that you need to pop out. After a little tugging you should see it. Stick a flat head right in between the bluck latch from the headlight and push whichever to the side of the corner light.
AaronL
Nov 15, 2020 11:52 AM
doctorpullit
Jul 20, 2019 09:31 PM
03VQMAX
Nov 10, 2015 03:39 PM
sdotcarter
Sep 2, 2015 09:53 PM
