Sponsored by:
Sponsored by: CARiD
Wiring Up Summit RPM Switch
Old Jul 29, 2005 | 05:37 AM
Ka$hThaRipper's Avatar
Originally Posted by 98SEBlackMax
The white/green tach RPM wire should supply adequate signal to activate the Summit RPM switch. I have used a summit switch to operate a VI..
The wiring hook up should be
red - 12V
black - gnd
white - tach sig
yellow - to the VI, green/yellow wire on VI harness
Also make sure the VI has a fused source of +12V also. Keep in mind the Summit was made for V8s so you have to mess with the RPM settings a bit. Set the summit switch to activate at 3000 rpm, that equates to about 5500 rpm on our cars IIRC... And finally I can't stress this enough but make sure to solder and heat shrink all the wiring, dont just wrap them together.
Where can I find this tach signal and also what color..I was thinking of using a tach wire behind the cluster, is this possible?
And my VI never came with the harness with loose wires, so my friend was just going to solder the wires to the 2 pins on the VI harness.. Which Summit Wire solders up to which pin??
And there's also one gray wire -- any comments on that??
I already referred to this thread:
http://forums.maxima.org/showthread....ng#post3817133
Old Jul 29, 2005 | 05:53 AM
laylow1988's Avatar
a soon as my car comes out the shop i'll post a pic of the screw that i used behind the tach for the rpm signal.
Old Jul 29, 2005 | 06:44 AM
SDot82's Avatar
Ok the tach signal wire is White with a green strip (#17, it should be in the middle plug located on the top far left of the plug, if your looking at it were all the wires go in). And yes it's possible because I did the same thing.
Next you want to solder the yellow wire (from the summit switch) to the right pin and the left pin connects to a power source like the cig lighter.
Also remember that the summit was made for a V8 so I think setting it to 2400 rpm will activate it at 4800 on our cars. But you may want to take it to a dyno to see what is the best time for it to activate on your car.
Old Jul 29, 2005 | 08:41 AM
Stephen Max's Avatar
The yellow wire opens up a ground path when the set rpm is reached. The gray wire does just the opposite - it provides a ground path until the set rpm.
For the MEVI or 00VI, you want to use the yellow wire. Just ignore the gray wire.
Old Jul 29, 2005 | 01:08 PM
ok thanks everyone..just want to make sure, can i get a confirmation:
1. Cig Lighter <--> Left Pin
2. RPM Switch Yellow <--> Right Pin
3. RPM Switch White <--> White w/ Green Stripe Wire behind Cluster
4. RPM Switch Gray <--> Ignore
5. RPM Switch Black <--> Ground
6. RPM Switch Red <--> Straight to Battery (with fused wire)
Old Jul 29, 2005 | 04:10 PM
s0ber's Avatar
where are u mounting the box in the bay or in the car?? Here's my setup
1) Power from battery <--> Left Pin
3. RPM Switch White <--> White w/ Blue Stripe Wire in ECU Harness
6. RPM Switch Red <--> Cig Lighter
Old Jul 29, 2005 | 04:37 PM
^^ well if that's the way you have it and since it works..it will make sense for me to mount it in the car somewhere since 2 RPM Switch wires go into the cabin and only 1 goes to the engine bay
Old Jul 29, 2005 | 08:30 PM
s0ber's Avatar
most people mount it in the engine but I found it easier for me to mount it in the car, plus I dont wanna get it wet everytime I wash teh engine..
Old Jul 30, 2005 | 12:25 PM
DandyMax's Avatar
3.5 in the works
Mines hidden up under my dash.. attached to the under cover on the driver's side. I also wired an led up beside the dimmer so I can see the light come on when it activates.
Old Aug 1, 2005 | 03:24 PM
mitch33x's Avatar
My Summit switch sits under the ECU, it fits perfect...
Old Oct 29, 2005 | 11:05 AM
XeroX's Avatar
Hella internets
Hate to bring this back from the dead, but which wire and which harness on the VIAS do i use to connect the RPM switch? There is a black plug and a brown plug on there, i have both of the harnesses, but i cant find anywhere specifying wich one to use, let alone which wire is suposed to be used for the "fused" power source that runs directly to the VIAS.
So for a quick summary: what wire is power on the VIAS, and which harness do i use? as well as what wire and harness do i run the RPM switch too?
Old Dec 6, 2005 | 02:06 PM
XeroX's Avatar
Hella internets
Figured it out with some help, its the BLACK plug on the VIAS...altho i think i have been the only one that got confused about this, figured i would post to help anyone else out that may have gotten confused as well
Old Dec 6, 2005 | 09:31 PM
Ceasars Chariot's Avatar
Old Maxima Legend
you rock !
Old Dec 8, 2005 | 07:41 PM
MaDMvD's Avatar
Thanks for the info, I'm going to need it in the near future (just got my 00VI today)!
Old Dec 12, 2005 | 09:02 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
Thanks as well....
I'm starting my 00VI installation on monday.......... fun stuff....
Old Aug 21, 2006 | 11:25 AM
jmeister's Avatar
Bump for the search impaired. Seems the MSD digital switch has the same corresponding wire colors
shilov
Feb 19, 2024 09:40 PM
JoshG
51
Sep 21, 2015 10:41 PM
Maxie40
Sep 14, 2015 11:28 AM
dcardello
Sep 3, 2015 11:44 PM
