Trans swap questions
I've posted in the 4gen forums but not much help there. OK I have 99 Max Cali emsissions, Auto, With Traction & ABS. I want to swap to a 5 speed but I got a couple of question.
1. I don't think that TCS came with a M/T but can I keep it? From the wiring diagrams it looks as if the TCS is the same module as the ABS. If not do I need to replace the ABS module?
2.Is it worth it to change to a 00 - 01 M/T transmission?
3. Which performance Clutch should I use?
4. When I swap the ECU for a M/T Is it gonna make a differance if that ECU has ABS or TCS?
5. Since it's a 99 which in alot of ways is closer to 5 gen are there going to be any problems that anyone can for see?
Thanks for any help. Joe
