y-pipe without catback exhuast good or bad
Old May 23, 2001 | 12:45 PM
ewood420's Avatar
I have intake and i just installed a cattman y-pipe, is it worth it?
Old May 23, 2001 | 02:25 PM
ybelm620
Yea, all you need now is a hi flow cat and a cat-back exhaust and yoo are set with the exhaust mods on your max. You can get a good hi flow cat from www.randomtechnology.com
Old May 23, 2001 | 02:31 PM
JDM4LIFE's Avatar
the Y-pipe's definitely worth it. as far as exhaust goes, if you really wanna spend the money, u can get that hi-flowing cat the other guy mentioned. also for catback, if you want a high-pitched sound, get the stillen, for a lower, droning sound, get greddy. if you want some small performance gains, but with as little sound as possible, get a stillen B-pipe and keep the stock muffler, or even better, install an Infinity I-30 muffler :-) personally, i don't see much at all of a performance difference between greddy and stillen, i went greddy cuz i got a decent deal on it. but if it came down to it, i'd go stillen becuz their products are top notch. good luck, and enjoy the Y!!
Old May 23, 2001 | 03:45 PM
MardiGrasMax's Avatar
Good!
Y pipe with intake, Better!
Old May 24, 2001 | 03:40 PM
got rice?'s Avatar
the catback exhaust in itself doesn't yield HUGe gains but when you work it in conjunction with a less restrictive intake tract and a Y pipe, you'll get the most out of it.
The setup you have now is fine, but you'll take full advantage of the higher flowing Y pipe section with a less restrictive exhaust path after the Y pipe. You can probably find an exhaust shop to make the B pipe section less expensive than a Stillen or Courtesy pipe, but I recommend you spend an extra few dollars on the muffler section. The less expensive universal mufflers generally sound terrible. The Stillen muffler section or an A'PEXi universal muffler would be a good match.
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
FlaMark
25
Aug 28, 2015 10:15 AM
Dasmith
Aug 25, 2015 10:15 PM
