Any 6spd owners get lsd with your car?
Old Aug 4, 2005 | 08:42 AM
maxmale's Avatar
i dont even see this as an option on nissan's website anymore and i could have sworn it used to be an option only on auto's.
Old Aug 4, 2005 | 08:47 AM
1Hot6Gen's Avatar
i got lsd with my car but i got it when the 6gen max came out in 2003, i have a 6spd
Old Aug 4, 2005 | 09:10 AM
maxmale's Avatar
yea i did to i got mine in like may/june of 03 and i could have sworn that you couldn't get the 6spd with the limited slip. what option/packages do you have.
Old Aug 4, 2005 | 09:57 AM
RHMax's Avatar
Newbie just Registered
LSD use to be standard w/ 6 speed 6th gen when first few months of 04 production. Don't know why Nissan did away with it. Alti SE-R 6spd had them in the beginning too.
Old Aug 4, 2005 | 10:00 AM
maxmale's Avatar
i am pretty sure i dont have this, is there a way to find out?
Old Aug 4, 2005 | 10:12 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
From what I remember, only the early 04 manuals where offered with a LSD, it was not an option available for any version of the automatic's.
Old Aug 4, 2005 | 10:26 AM
RHMax's Avatar
Yes. do burn outs and see tire marks
Old Aug 4, 2005 | 10:32 AM
RHMax's Avatar
Gerealizing here, LSD makes FWD cars tougher to trun. 1 way LSD works best in FWD, but uneven driveshafts counter the effect a bit.
Old Aug 4, 2005 | 10:53 AM
Maxium's Avatar
Thread hijack for a sec:
RHMax, most LSD's will only engage when one wheel is slipping. By slipping I mean one wheel is spinning faster then the other. The clutch packets wined up until a set of toothed coupling engage, that engagement locks the wheels up. Most “good” LSD’s work after the spinning wheel completes 1 1/2 ~ 2 full revolutions, and then the nonspinning wheel will engage. This is also called a Differential locker, and does not effect your turning ability under normal driving environments. If you had a spool or e-locker I promise you the turning ability will be effected. Using a spool, on the gas, and attempting to make a turn will cause one of the tires to skid, chirp, hop, and clunk – an awful noise, all this because it’s spinning slower then the faster wheel and there is no play with a spool or e-locker. on a flip side, drag racing. A straight line and perfect that for that kind of driving.
Old Aug 4, 2005 | 11:12 AM
RHMax's Avatar
I believe the term I used was "generalizing". When you turn w/ FWD cars, the outside wheel spins faster than the inside wheel. So when you add gas to get out of turn, the wheels are still "slipping" thus your "slipping" point goes here. Once you are used to having LSD in FWD, you'd adjust your driving style. Try driving Integra GSR versus Type-R. Similar reason to why only RWD cars with ample power come w/ stock LSD,so they can push their way out of a turn.
Old Aug 4, 2005 | 01:49 PM
gen2000's Avatar
In 2005 Nissan exchanged LSD on manual 6 speeds to,Vehicle Dynamic Control and full size spare
Electronics are cheaper.
Old Aug 4, 2005 | 02:36 PM
e_marston's Avatar
Actually, I asked my dealer's service rep and Nissan replaced the LSD with VDC due to complaints from noises it was apparently making. Not all the LSD's had this problem, but I was lucky enough to pick up my car in March 03 so I have LSD. No noise issues for me. So from that respect maybe electronics were cheaper
Old Aug 4, 2005 | 04:20 PM
daves04smoke's Avatar
The "Other" project
myself with a 6spd really prefer an "open" final drive. With the torque steer I think it is actually a little easier on the driveline. I have not driven one with a LSD but just from my experiences think it would really affect the way it handles and drives through the gears.
Old Aug 4, 2005 | 04:23 PM
CanadianMoFo's Avatar
All 04 6sp in Canada came with LSD.
Lakersallday24
Jun 16, 2019 01:35 AM
WeetoddA32
Aug 16, 2015 12:45 PM
MikesChevelle
Aug 14, 2015 12:31 PM
Supragte
Aug 12, 2015 10:00 PM
Team STILLEN
Aug 10, 2015 04:29 PM
