URGENT Car won't start Clicking Noise URGENT HELP NEEDED
Old Aug 13, 2005 | 07:31 AM
teeezmaxSE's Avatar
After I left work last night, I started my car and the battery light as well as the brake light in the instrument panel were on and stayed on. I drove for about 25 minutes or so, not realizing what was wrong.. Anyways, as I was about to get onto my exit, the radio turned off and then came back on (all presets were gone) and the right side of the clock started to dimm. I'm thinking that this is the battery telling me something. Anyways, I drove as fast as I could, not putting anyone in harms way of course also at 3am, and drove intoa parking lot near fiance's house... Anyways.. long story short, car dies, radio works, lights work, full power, just when I try to start the car, it clicks rapidly and doesn't start. I just got my alternator changed about 4 months ago or so and just changed my ignition switch about 3 weeks ago. Has anyone had this issue or know what it might be. Its currently in the store parking lot. I'm trying to figure out what to do and would like any and all advice. This is urgent.. Please help!!! Thanks
Old Aug 13, 2005 | 07:58 AM
laylow1988's Avatar
to tell you the truth i don't know
Old Aug 13, 2005 | 08:08 AM
99Automagic
OMG The battery and brake light came on at the same time
ALT fuse has blown. It is located under the hood in the fuse box near the battery. It can alos mean the voltage has dropped under 10v. In most cases this means your Alternator is dead/shorted out. Replace the fuse when you replace the alternator.
Just found this in search. Just something for you to check out.
Credit - Kevlo
teeezmaxSE's Avatar
ha....Thanks.. .. Its ok.. At least you participated and gave it your best
Old Aug 13, 2005 | 08:36 AM
dukelubas's Avatar
Org Lurker
These are the exact symptoms of having loose or corroded battery terminals. Remove, clean and reinstall the terminals and make sure they're tight.
Old Aug 13, 2005 | 08:58 AM
teeezmaxSE's Avatar
Excellent.. I'll try that when I reunite with the max again.. Thanks!!!
Old Aug 13, 2005 | 01:31 PM
cds166's Avatar
Yeah check the battery terminals
Old Aug 14, 2005 | 04:35 PM
Garrick's Avatar
It could also help to check the starter. My Maxima had the same problem and $445.70 later, it turned out to be the starter.
Old Aug 14, 2005 | 05:00 PM
teeezmaxSE's Avatar
OK.. so I checked out the battery terminals today. Although there were signs of corrosion, that wasn't it. I cleaned it off and tried to start it and still wouldn't start. I noticed that although the lights came on, they were dimmer than usual. My door lights (the light inside the door that alert's other drives that you have your door open) turns off when the door is open and I turn on my headlights. Another thing too was that I jump started it and it actually started, however, as soon as I disconnected the jumper cables, it started to sputter until it eventually died. It died actually when I turned my headlights on. So, I'm thinking that it could possibly the alternator, although I DID change my alternator in January of this year. Any thoughts? Thanks
Old Aug 14, 2005 | 05:28 PM
joooowan
same exact thing happend to my camry. even though it wouldnt jumpstart, i changed the battery and it fixed the problem.
Old Aug 14, 2005 | 05:35 PM
teeezmaxSE's Avatar
But wouldn't it make more sense that if my battery was dead and I was able to jump start it, the car would still be running until I turned it off? THe car was jumpstartable but then slowly died when I disconnected the cables.
I got a new battery in 2004, Its a diehard and I'm sure that wouldn't be the case but I could be wrong..
Old Aug 14, 2005 | 05:37 PM
Garrick's Avatar
Check your door and accessories to make sure they are not on. Jump your car and let is sit connected for like 5 minutes. Something is draining your battery.
Old Aug 14, 2005 | 05:38 PM
Loe max's Avatar
its your alternator..
Old Aug 14, 2005 | 05:42 PM
teeezmaxSE's Avatar
another thing I noticed too.. not sure how but as I was sitting there and of course the car was dead and the keys were in my pocket and noticed that my antenna was still up. The radio aws off, actually, the whole radio face plate was off but the antenna was still up. Not sure what that was about. Put the radio in, turned it on and then turned it off and the antenna went down. Could that just be some form of a short to add to everything else thats going on?
Old Aug 14, 2005 | 05:44 PM
Loe max's Avatar
Go get your charging system checked, its as easy as that. NmexMAX where are you in this desperate time of need?
Old Aug 14, 2005 | 05:48 PM
Loe max's Avatar
A starter problem won't light up the battery and brake light as well as dim the lights when you're driving.
Old Aug 14, 2005 | 05:49 PM
Loe max's Avatar
Listen to this guy
Credit - Kevlo
Old Aug 14, 2005 | 05:53 PM
Garrick's Avatar
Oh it was while you were driving? Sorry Noob-mistake.
Old Aug 14, 2005 | 05:55 PM
blinelaxd27's Avatar
make sure ur belt did not come off the tensioner. It would mean ur alternator isn't being turned. check that
Old Aug 15, 2005 | 08:47 AM
teeezmaxSE's Avatar
Hey Everyone...
So I called AAA this morning (4 hour wait last night due to thunderstorms/flash floods.. no thanks.. ) They came and then called the battery guy. He came to test things out.. says it the alternator. I had the alternator replaced in February, so hopefully I don't get charged for it.. I shouldn't get charged anything right? He also said that the battery was gone, got that in Feb of 04.. The result was that the alternator was bad causing whatever to suck the juice out of the battery, therfore, both suck ***** at the moment.. Its in the garage now and just waiting to get the call back to pick it up..
Thanks everyone for chiming in.. but let me know what you think regarding the garage and payment..
Thanks!
Old Aug 15, 2005 | 10:32 AM
Loe max's Avatar
Was there a warranty with the alternator? Call your local Nissan dealer and see if your VIN # falls within the Alternator recall for model year 1997.
Old Aug 15, 2005 | 10:46 AM
teeezmaxSE's Avatar
Sorry.. I thought I put this in..
I had the alternator fixed back in January or so through a garage..I didn't see any written warranties with the alternator, but it was a reman and its been 6-7 months..would they have the nerve to charge me? I mean. I can see if its over a year or so but a few months like that?
Old Aug 15, 2005 | 11:23 AM
Norm_Nav's Avatar
As I newbie, there is little I can add,,,my 1996 I30 seems entirely flakey in the electric department as well...Finally took it to Infiniti dealer, he calls and says it's the alternator,,$430? plus he'll change the belts $69 ,,,But what part of this would make the idiot lights flicker with the key in the on postion, prior to starting?? and why would the radio volumn go down or off when the lights were turned on (this lasts only a second...) I have had this car two weeks today,, so far we are just at the $700 mark trying to get it to start right,,once started, it runs fine,, no CEL,,I'm unable to check codes due to flickering cel light with key in "ON" position,,,
Old Aug 15, 2005 | 11:30 AM
Lawtown's Avatar
I'm not trying to steal your thread but I'm having the same problem. First on Saturday my brake and battery lights both turn on. Then on Sunday all my lights turn on ABS, etc.. and my car doesn't want to change out of second gear untill it finally died at the gas station. I got it towed home and check for codes and got 1104 something to do with a solenoid or something. So I'm stuck with out a car right now and it sucks big ones cuz i don't know what to do yet and it's been raining.
Old Aug 15, 2005 | 04:25 PM
Loe max's Avatar
All of your red warning lights will come on one by one as soon as the voltage drops little by little until the lights either dim or flicker if your charging system is being drained when the car is on. As for the Transmission, it could either be a seperate problem or a problem linked with a lack of communication between the Transmission Control Module and the Engine Control Unit.
Old Aug 15, 2005 | 04:27 PM
Loe max's Avatar
Alternator from a parts store=$100-$150
Serpentine belt=$10-$15
Time to install the alternator=15-30mins
Time to install the Serpentine belt=5-10mins
Having a dealer put it in=butt rape
Old Aug 15, 2005 | 07:35 PM
teeezmaxSE's Avatar
Thread Hijacker... .. hey.. this is the place to tell your problems!...
as for the warranty question.. no.. I actually have never heard of a garage putting a warranty on a reman alternator..
Old Aug 16, 2005 | 05:47 AM
Loe max's Avatar
The company that made the reman alternator typically will have a warranty. Otherwise your SOL and have to fork over cash for a new one.
Old Aug 16, 2005 | 06:35 AM
teeezmaxSE's Avatar
I got my car back this morning.. They take care of their customers..They didn't charge me and my baby is back.. Thanks everyone for your input...This maxima family is TIIIIIIIGHHTT... Peace out... Until the next problem that i need the orgy-ers advice that is .....
Old Aug 16, 2005 | 07:20 AM
Norm_Nav's Avatar
I was Raped!!! however, I was really having palpitations trying to get this thing right,,,Had I been driving it a bit longer, perhaps I would have had a better notion of what was going on,, but I got frustrated,,So,, as a learning experience,,I guess I had it coming.. also note: the CV boots are broken,,the left outer growls above 50mph,,So I know I have this looming as well.. went to Motorvate,, saw how the operation is performed...I'm thinking changing them myself might be a bit too much..I'll have to ponder it a while..
Old Aug 16, 2005 | 11:46 AM
Lawtown's Avatar
What did they do to fix your problem and how much did it cost?
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
Samedi
Aug 13, 2015 04:05 PM
