If I get Coilovers such as Tein or KSport...
Old Aug 14, 2005 | 05:01 PM
Black Maxima
If I put coilovers on my ride, what other parts are necessary? Do I need strut mounts, bearings, and/or bumpstops? I'm going to need expensive items besides the shocks and springs. So maybe coilovers are the way to go?
Thanks, Aaron
Old Aug 14, 2005 | 05:21 PM
Black Maxima
Camber Kit also?
BUUUUUUUUUUUUUUUUUUUUUUUUUUUUMP!
Old Aug 14, 2005 | 05:55 PM
Black Maxima
Uuuuuuggggggggh.
Old Aug 14, 2005 | 07:16 PM
Rick James's Avatar
Originally Posted by Black Maxima
Uuuuuuggggggggh.
Im wondering the same thing.
I want to get the KSPORTS and would also like to know what other parts i need.
Also how do you get all corners to be the same height?
Old Aug 14, 2005 | 07:19 PM
sunten1
With Ksports you don't have to buy anything its all there...all you do is swap the stock strut/spring combo with the one that you buy, but with ksport all you have to do is installed it you don't need a spring compressor becuase the coilovers come assembled
Old Aug 14, 2005 | 07:22 PM
Black Maxima
EVERYTHING is there? Including bearings and mounts? Dust boots are not needed? Sunny, find me that KSport thread. Your good at finding that stuff. Thanks!
Old Aug 14, 2005 | 08:25 PM
sunten1
Since BLACK MAXIMA already found the link and is SOOO selfish ill post the link...
http://forums.maxima.org/showthread.php?t=406790
Old Aug 14, 2005 | 08:55 PM
Black Maxima
Thank you sir!
Old Aug 15, 2005 | 12:26 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
wiht ksports/d2's, what you get is what you need. everything comes with the coilovers, including camber plates.
Old Aug 15, 2005 | 12:35 AM
ImmaSquashYou's Avatar
k-sport d2's coems with everything and is made like the tein flex. but they don't have that for the 4th gen. to get the same height through each corner is the hardest part. once lil adjustment will throw it off..took me a while to get every corner almost the same height but amber plates n pillow upper monut com with it...everythign you need is there..you will however re-use 5 bolts in the front n 3 botls in th rear
Old Aug 15, 2005 | 08:07 AM
Black Maxima
Thank you! I believe I am getting KSports now. Since Illuminas, S-Techs, and the other parts, such as strut bearings, mounts, etc. will jack up the price to around $1100.
Old Aug 15, 2005 | 08:50 AM
maxspeed96CT's Avatar
The original VQ...
i have tein basics, i didnt need anything else, but camber bolts and plates would help with the alightment.
MaximaSE96's Avatar
Maxima Owner
where r u shopping........if u get new mounts they have bearings.....and they are like 50 bux a piece.....dust boots are way cheap so are bumpstops for the rear....in all u should pay no more than 750 for spring strut combo with all the xtras.....but k-sports would still be better.....and u can also get TEIN BASIC coilovers for round 750 too
Old Aug 15, 2005 | 08:55 AM
Black Maxima
How do you like them? Any noises? Camber plates only come with the KSports? Maybe I should get Tein Coilover...
Let me run downstairs and break down the prices to show you.
Old Aug 15, 2005 | 08:58 AM
MaximaSE96's Avatar
Maxima Owner
if u factored in camber plates i can see how it would be soo high.....i forgot they are like 250-300 dolalrs
Old Aug 15, 2005 | 09:11 AM
The original VQ...
I love the teins, no noises and good ride.
Alittle bouncy now that i slammed them realy low.
And my camber is alittle negitive but its nothing to complain about.
I never drove in a car with k-sports but most poeple that have them like them , and i hear alot of people with D2 have problems with noises or blown struts, just doesnt sound like a good product
Old Aug 15, 2005 | 09:12 AM
Black Maxima
Shocks: $435
Springs: $150
Dustboots: $68
Bearing: $31.95 x 4
Bracket: $19.98 x 4
Insulator: $40.70 x 4
Total: $1023.52
Did I forget anything. All these parts should be necessary...
Coilovers (for example KSports): $820 shipped
Old Aug 15, 2005 | 09:13 AM
Black Maxima
Thanks for the quick reply. Where did you get you Teins? I see them on eBay. How low did you drop your whip?
Old Aug 15, 2005 | 09:15 AM
MaximaSE96's Avatar
Maxima Owner
u can reused insulators and brackets.....2 would only need 2 bearings for the front and u get kyb mounts they are already there and only 40 bux a peice
Old Aug 15, 2005 | 09:22 AM
Black Maxima
I don't know if I could reuse any parts. I hear popping and rumbling noises going down the road.
I never got a solid answer of what I would defineatly need for a suspension installation.
Old Aug 15, 2005 | 09:35 AM
MaximaSE96's Avatar
Maxima Owner
ok here is what i def suggest if u go spring strut
1. new front mounts KYB makes ones with bearings already set to go just put the new mount in
2. Spring of your choice and Strut of your choice
3. Camber plates if ur lower than 2 in....i am 2.2" lower dont have them and i am fine
4. i would get the gasket thingy that goes between the mount and frame of car....(i du nno if those were the isolators u were referring to.) i made my own out of foam from craft store..
rumbling and poping can be ball-joints an wheels bearings as well.....
but if u have the cash i would say a true coilover....TEIN Basics are perfect the only thing is they arnt dampening adjustable.....but from what i hear they are designed so goo u dont need the adjustability.......so i would thinkg about it....any other ? feel free to drop a pm......i have done 3 diff suspension setups in 2 differnet maximas.....
Old Aug 15, 2005 | 01:03 PM
i have d2's. i fixed my noise issues by puttin no pre-load on the spring. i drove already about 12,000 miles since april n not a blown strut. tein basics require you to re-use some old parts ratehr than just the bolts. the tein requires you to re-use the stock upper mount. or you have to go out and buy them. they are expensive. lemme tell you. i'm not saying that tein's aren't great, i love them since i did have the tein SS on my accord, but the price for te k-sport n d2's were something i couldn't wait for
Old Aug 15, 2005 | 02:58 PM
Black Maxima
I like the idea of adjustable ride height. I'm pointing more towards coilovers I think. I have to talk with my dad...
Old Aug 15, 2005 | 04:22 PM
Vlasic's Avatar
the first batch of D2s in the countyr had problems with blown struts. I have not heard of anyone that got htem after that first batch that have had strut problems. also, I have barely any noise issues.
Old Aug 15, 2005 | 09:52 PM
The original VQ...
i got my teins from sport compact only,
My car is pritty low right now, im on 17s with 50 profile rubber and the gap is about the size of a childs pinky.(i dropped more since the pic in the sig)
Im in new britain ct, let me know if you even wanna meet up and see my setup or anything, im on the pike once i na while to.
Old Aug 16, 2005 | 08:25 AM
Black Maxima
Yea, I have 17" wheels and 50 rubber around them too. I am leaning towards the KSports right now, but I would like to see your whip anyway. I'm like 3 seconds from New Britain.
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
Ben2003GLE
Sep 24, 2015 04:25 PM
