30K Tranny flush for .....
Old Aug 15, 2005 | 03:13 PM
JayMAX22's Avatar
$126.84 !!!! That's right !!!! I went in and I asked the service manager how much it would cost me and he said he had a special going on for $129.00. Apparently he didn't know that the Maximas used the special fluid. Needless to say, they realized the mistake and they still honored the price they quoted me. What was the actual price that I was suppose to pay?
Old Aug 15, 2005 | 03:22 PM
akaxmrxhammer's Avatar
you got lucky there. it's like $15 per quart.. and how much fluid does the tranny hold?
Old Aug 15, 2005 | 03:26 PM
maxmale's Avatar
i believe its like 4-5 quarts but i dont know about the auto.
Old Aug 15, 2005 | 03:30 PM
i wonder why nissan decided to use a special tranny fluid for the 5sp auto.
Old Aug 15, 2005 | 05:53 PM
JayMAX22's Avatar
I told me that it's $16.50 per quart and it takes 6 quarts.
Old Aug 15, 2005 | 06:47 PM
NismoMax80's Avatar
SuPeRmOd
special fluid so you only buy it from them, duh! I like to hope b/c our manual/auto is so unique....
I'll be searching for possible alternatives or sales to do it myself. I mean all we do is dump xx amount and replace it w/ xx amount right? they say they can't flush it all. simple dump and replace a portion of it.
Old Aug 15, 2005 | 10:00 PM
isn't it like almost $200 for the tranny fluid change at the dealers? i'm with you nismo on the do it myself tranny fluid change. talk about a rip off! time for some research on the org. i know we talked about this a while back.
Old Aug 16, 2005 | 03:22 AM
JayMAX22's Avatar
Right. It was a simple dump and refill. They said the tranny doesn't have a return line so you can't flush it.
Old Aug 16, 2005 | 07:16 PM
MaxFan's Avatar
Drain Plug's location ?
Anyone help me out on this. I've been under the car a few times looking for it. I saw a small black pan on the drivers' side and there is no plug.
Old Aug 16, 2005 | 10:51 PM
SilverMax_04's Avatar
That is certainly the correct side. I suspect they have it so you have to drop the pan and check and clean the screen.
Shouldn't this all be moved to the lubes section of this site?
Old Aug 17, 2005 | 04:05 AM
NismoMax80's Avatar
SuPeRmOd
it's on its way there....
so someone figure out how to dump the tranny fluid before this thread dumps into lube land.
Old Aug 26, 2005 | 07:04 AM
willysmooo's Avatar
i paid like 156.00 for mine to be changed, they changed 5 quarts. You wanna hear something really scary, the service guy told me that he could only change out about 5 quarts, but the trans hold about 20 quarts in it. I really dont think so...he said yes it does....thats kinda scary when the guy working on your car(at a nissan dealer) tells you there is 20 qs. of fluid in the trans. DUH!
Old Aug 26, 2005 | 02:54 PM
NismoMax80's Avatar
SuPeRmOd
Truth. Consistent with everyone I've spoken too. That's how it's done.
Old Aug 26, 2005 | 03:10 PM
RHMax's Avatar
Newbie just Registered
So the tranny hold 5 gallons of fliud, like submerge in it? How does it cool?
Old Aug 26, 2005 | 03:19 PM
NismoMax80's Avatar
SuPeRmOd
20 quarts... yeah I guess that would be 5 gallons. sorry, no sleep owns me. I think it is more than 10 though. whatever the total amount, we can't drain it all. 5 in and out, but a good amount is not changed. 5 gallons, my bad
edit:
Originally Posted by SM
4. Refill the transaxle with new specified A/T fluid through the A/T fluid charging pipe. Always refill the transaxle
with the same volume amount that was drained out.
doesn't even say how much is total. Obviously just draining and refilling is not a flush and some will be left in. At least we know to buy 5 quarts. Would suck to be cheap and buy 4, measure how much we dropped, and be stuck at home trying to get another quart from Nissan.
Old Aug 26, 2005 | 03:24 PM
RHMax's Avatar
Sorry, I thought 5 gallons make more of an impact than 20qts. I guess I was right! I'll have to confirm w/ my mechanic.
Old Aug 27, 2005 | 11:55 AM
valvestud's Avatar
From the Nissan service manual:
Changing A/T Fluid
1. Run the engine to warm up the transaxle until the fluid is at full operating temperature of 50-80C (122-176F).
2. Stop the engine.
3. Drain the A/T fluid by removing the drain plug. Reinstall the drain plug to the specified tightness using a new drain washer.
4. Refill the transaxle with new specified A/T fluid through the A/T fluid charging pipe. Always refill the transaxle with the same volume amount that was drained out.
CAUTION:
Do not overfill the transaxle.
Drain plug torque
4 A/T: 29 - 39 Nm (3.0 - 4.0 kg-m, 22 - 29 ft-lb)
5 A/T: 23.5 - 54.9 Nm (2.4 - 5.5 kg-m, 18 - 40 ft-lb)
Fluid grades
4 A/T: Genuine NISSAN Matic “D” ATF (Continental U.S. and Alaska) or
Canada, NISSAN Automatic Transmission Fluid. Refer to MA-10,
5 A/T: Genuine NISSAN Matic “K” ATF. Refer to MA-10, "RECOMMENDED FLUIDS AND LUBRICANTS".
Fluid capacity (with torque converter)
4 A/T: 9.2 (9 3/4 US qt, 8 1/8 Imp qt)
5 A/T: 7.3 (7 3/4 US qt, 6 3/8 Imp qt)
Old Aug 27, 2005 | 05:09 PM
MaxFan's Avatar
Where's exactly is the plug ?? Please. Anyone knows ?
Old Aug 27, 2005 | 07:08 PM
Burny's Avatar
on the driver side very near the engine oil reservoir. you can access it from under the front of the car. Engine oil bolt is a 14MM, the Tranny fluid bolt is much bigger.
Old Aug 27, 2005 | 09:31 PM
valvestud's Avatar
Depends on whether it's the 4 speed or 5. The 4 speed plug is in the bottom of the pan and is recessed up into the pan. The 5 speed is on the side as in the description from Burny.
Old Aug 28, 2005 | 08:05 AM
MaxFan's Avatar
I used to change trans oil on my '97 4spd and the plug was exactly ;ile you said. Now, for the 5spd, do you mean it's on the "side" of the black pan. I saw a small but taller black pan on the driver's side. I will check again today. The last few times I checked, I didnot see any plug but a bunch of tiny ones to take the whole pan out.
Old Aug 28, 2005 | 10:41 AM
MaxFan's Avatar
Valvoline has a statement indicating it can be compatible with Nissan stuffs. The oil is available on the shelf:
https://www.valvoline-technology.com/data/valv/prodinfo.nsf/0/85256AE300727D2BC1256BB900456C51/$file/Maxlife+ATF.pdf?OpenElement
They mentioned not really doing a long-term test yet. But by looking at the chemical contents, it has the required and more.
Old Aug 28, 2005 | 10:53 AM
willysmooo's Avatar
ya..the only thing is that anything else than the nissan k-matic stuff, gets or voids nissan out of the warranty.
Old Aug 29, 2005 | 06:34 PM
MaxFan's Avatar
I wouldn't want to use Valvoline for now. But the future looks good as I can see at least 2 sources paying attention to Nissan's Matic K. Well, I would be more interested when the Max is long out of any warranty. $15/quart for Nissan or $3/generic is tempting. Especially if there is a syncthetic
oil available for <$5, stating it would exceed Matic-K specifications.
Old Dec 21, 2005 | 03:07 AM
okay guys, this is what i've found. i've been searching the org to see if anyone had tried using different tranny fluid other than matic k for the 5spd, and i didn't find any. i was about to hit the sack and did a one last search on "nissan matic k" on google, and this is what i found. check it out and tell me what you guys think.
http://www.bimmerboard.com/forums/posts/52539
Old Dec 21, 2005 | 05:07 AM
factorymax's Avatar
I used to be a district manager for Nissan and I can say with 100% certainty...DONT USE ANY OTHER FLUID THAN NISSAN MATIC K.....PERIOD.
YOu will void your warranty faster than you can say "Oh ****". If you ever have any troubles with yuor tranny and the dealer finds out you have used another fluid, you are done.
Please take my advice as I have seen it many times before.
Old Dec 29, 2005 | 09:51 PM
MaxFan's Avatar
I came to the dealer today to pick up some oil-filters onsale for $4.95/each. They didn't have anything special for K-matic. But the guy told me it's $9.95/quart. So I got 5 quarts. I guess this is their regular price.
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
RWCreative
Sep 21, 2015 11:01 AM
pktaske
Sep 4, 2015 08:40 AM
