What tire size are you running????
Old Aug 16, 2005 | 08:13 PM
CyMax's Avatar
I'm interested in getting slightly wider slightly lower profile tires , but I have no idea what will fit, or what wont. So, if you know lemme know too. Thanks!
Old Aug 16, 2005 | 08:32 PM
Dave H.'s Avatar
what size rim you using?
Old Aug 16, 2005 | 08:44 PM
VIP Maxima
exactly lol
Old Aug 16, 2005 | 09:33 PM
CyMax's Avatar
Whoops!!! Sorry about that, just stock 92SE rims.
Old Aug 17, 2005 | 06:44 AM
Cliff Clavin's Avatar
Way out West
The stock SE wheels are only 6.5 inches wide, so you can't do anything too dramatic.
Stock size is 205/65/15, so you could go with a 215/60/15 and be just a little bit wider and a little bit smaller. Your speedo will be off just over 1 percent. Maybe a 225/60/15, which would actually be closer to the stock tire circumfrence, but I don't know if the 225s are too wide for the rim.
You want to stay with tires that have about the same circumfrence, or your speedo will be all wacked. If you want something low profile, you will have to go up in wheel size to probably at least 17x7.
homeyclaus
Sep 3, 2015 06:15 PM
NissLover
Aug 22, 2015 10:26 AM
maximaham
Aug 20, 2015 10:23 AM
