I'm interested in getting slightly wider slightly lower profile tires , but I have no idea what will fit, or what wont. So, if you know lemme know too. Thanks!
Quote:
Whoops!!! Sorry about that, just stock 92SE rims.Originally Posted by Dave H.
what size rim you using?
The stock SE wheels are only 6.5 inches wide, so you can't do anything too dramatic.
Stock size is 205/65/15, so you could go with a 215/60/15 and be just a little bit wider and a little bit smaller. Your speedo will be off just over 1 percent. Maybe a 225/60/15, which would actually be closer to the stock tire circumfrence, but I don't know if the 225s are too wide for the rim.
You want to stay with tires that have about the same circumfrence, or your speedo will be all wacked. If you want something low profile, you will have to go up in wheel size to probably at least 17x7.
