Someone Did not make a smart Move..
Hello Fellow Maxima Owners
I have a Nissan Maxima 95, which i adore.
EDIT:AUGUST 17 11:20 PDT
I jus got these led lights how would i install using the 12V cig lighter as the power source?
please tell me step by step, my english is not fluent
Originally Posted by 86maxima96
what's the problem? the problem is you're puttin neon in the interior. but other than that, check the fuses in he fuse panel. you should always have spare fuses on hand.
The Problem is the cigrette lighter isnt working at all, it used to work though..
you thinking i should buy a new fuse?
Wait I did the same thing well sorta...
I just popped a fuse
Basically I was wiring leds into the vents (rice i knows) and I wanted to make sure that the wire was hot behind the cig lighter
So what I did was I touched the led wire to the cig and it sparked and i blew out my fuse you should be fine
The fuse is located under there dash about where your left knee would be...(hey that rhymes hehe)
Here is the link to my post...
http://www.forums.maxima.org/showthread.php?t=356185
Hope that helps...
Hope that helps...
Originally Posted by 99Automagic
Never!!! After the first time I blew the fuse to my cig lighter, I went out and bought a whole pack of 10 fuses just for the lighter.
(no offense to smokers)
Originally Posted by goldtooth
With facts being given, using a gun can give the same effects but much quicker.
(no offense to smokers)Yea yea, so can eating too much meat, having too much sex, blowing a vein while masturbating, there are lots of ways we can go. Wait, that's not really an argument, I do all of these, cept the too much sex thing. I'm an honest guy. I won't lie.
I made a bad move
Tried to wire these neon lights rather then a AC connector. when i wired it into the 12V, i kinda so called jammed (cigrette holder) it back with force.
Now my 1. Neon lights dont work 2. The Cigrette Bud Doesnt work at all
Whats the problem?
Buy a Fuse?
Totallly Broken?
I really want fixed, boy im pist
I made a bad move
Whats the problem?
Buy a Fuse?
Totallly Broken?
Originally Posted by Garrick
If you adore it, why do you smoke in it?
lol i do not smoke at all.
Question:
1. How Can i wire my LED lights using the 12V provided by my cig lighter?
Which is the + and - ?
2. What does the word ground mean referring to swithes?
3. If someone provides me step by step detail, w/ pictures il send them 3 or 5 dollars through paypal.
I made a bad move
Whats the problem?
Buy a Fuse?
Totallly Broken?
I made a bad move
Whats the problem?
Buy a Fuse?
Totallly Broken?
Is the plastic part actually broken or are you simply not getting power to the 12V outlet? As others suggested, it could be a fuse, but if that doesn't work, take apart that part of the console and see if you damaged the back of the outlet.
What circuit were you trying to tap into? Were you going to have them on a seperate switch, or maybe on with the parking lights?
Also, take your time and type this stuff out in english. We can answer your questions better if we understand what you're saying.
Enjoy your neons!
ground is usually gunna be black color wire, if im not mistaken... which is "-"
So you splice into the red or orange wire from the cig lighter, thats the +.
and for the -, which is black/ground, you can put it under a screw or to anything thats metal. and there you go it should work.
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
