Will these fit on my 4th gen?
Old Aug 18, 2005 | 03:07 PM
_ck69_'s Avatar
I'm looking into getting a set of used volks, but I wanted to run this by you guys before I do. Will 18 x 7.5 48+ offset and the rubbers r 225/35/18 fit properly on my 4th gen? And... will it clear a Cobra BBK? Thanks for your help in advance.
Old Aug 18, 2005 | 03:24 PM
1FSTMAX's Avatar
probably not..
Old Aug 18, 2005 | 04:51 PM
_ck69_'s Avatar
what would be the problem?
Old Aug 18, 2005 | 04:54 PM
Bonka's Avatar
Schnell kaputt
Offset is too high. May rub on the inside. On offset alone it won't clear the 300zx caliper. Depending on spoke design you'll need at least a 10mm spacer. What model are the Volks?
Old Aug 18, 2005 | 05:05 PM
_ck69_'s Avatar
I'm a little confused...
So, the wheels WILL fit, but the BBK will not unless I get some spacers. Is this correct?
Old Aug 18, 2005 | 05:15 PM
Bonka's Avatar
Schnell kaputt
Correct. But at +48, it's definitely a Honda offset. Might be too high and rub the strut. It'll definitely rub on the inside tire well. If you want them, meet up with the seller and test fit them.
Old Aug 18, 2005 | 06:46 PM
_ck69_'s Avatar
damnit! I didn't want to hear that. I'll have to get the wheels mounted to check them out. Thanks for your help Bonka!
Old Aug 18, 2005 | 10:01 PM
browne's Avatar
someone here told me they put on 48 offset on 4th gen and it fit fine. let me know if yours fit cuz i got a great deal on the same size rim and offset.
Old Aug 19, 2005 | 12:58 AM
Bonka's Avatar
Schnell kaputt
I suppose if you get 5mm spacers for the front and rear it'll work fine.
Depending on how much those Volks are going to set you back it might be better finding a set with a proper offset for the Maxima.
At any rate, test fit them, if you like them and if the price is real good just get them.
Old Aug 19, 2005 | 08:58 AM
dubsonmax's Avatar
It will definately fit but it will rub in the inside fender wall. And u will need spacers to push them out a little. I know because i have 20 X 9 with a 45 offset. Hope this helps any.
Old Aug 20, 2005 | 06:15 AM
IIColinII's Avatar
Anyone knows if the 6th gen oem SE wheels and the 5th gen OEM se wheels will fit on a 4th gen max without any rubbing or so? or i might need spacer or something?
Old Aug 20, 2005 | 06:52 AM
1FSTMAX's Avatar
i have 48mm offset.. they don't rub..
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
mclasser
Sep 6, 2015 09:05 AM
Lowered_a33
Sep 1, 2015 07:49 PM
