245/35/19 Tire Owners Only
Old Aug 23, 2005 | 07:43 AM
Deckdout2's Avatar
Play with my balls
Quick question for you guys with this tire size. I'm currently running Proxes 4's, and have my tire pressure set at 35psi all around. Just curious what everyone else with this size is running? Should I be closer to 40psi? At 35 my traction is pretty good, but just seems like my pressure is low (eye-gauge). The max psi for these tires is 55psi listed on the sidewall, but that seems too high. Fill me in please.
Old Aug 23, 2005 | 04:14 PM
Bonka's Avatar
Schnell kaputt
I run 38psi all around. Personally I prefer to run at least 36psi for all sidewall thicknesses. Gives me a little less rolling resistance.
Old Aug 23, 2005 | 04:54 PM
VIP Maxima
im set to 40 psi cuz thats what it says on the tires. but when u run 19's u loose air easily. so i gotta go pump more air in every 2 weeks.
Old Aug 23, 2005 | 05:21 PM
carnal_c30's Avatar
Former Sponsor
I run 40-42 psi in my tires, Bridgestone Potenza S02s... ride aint so great but its better than running low psi in 35 profile tires
Old Aug 23, 2005 | 06:13 PM
Ammi's Avatar
350 Detroit Muscle
Used to run 37 psi all around
Old Aug 28, 2005 | 09:24 PM
1HOTMAX's Avatar
38 all around
Old Aug 30, 2005 | 02:04 PM
00SEMAX19's Avatar
Why would 19's loose air easily? I've never had a problem with this.
Sorry for barging in with my 235/35/19's but I run 40psi
Old Aug 31, 2005 | 12:39 AM
Juice_818's Avatar
same here.. 235/35/19 40psi
Old Aug 31, 2005 | 08:36 AM
falconey's Avatar
sounds like you don't have the correct width tire....
Old Sep 2, 2005 | 09:56 AM
2K3MAX2NV's Avatar
"tse-tse fly"
ive got the same wheels as hotmax with 225 35 19 toyo proxes and I lost air last night on one of my tires I would also like to know what psi is good thanks!
Old Sep 2, 2005 | 11:04 AM
VIP Maxima
45 on 8" isnt correct??
Old Sep 5, 2005 | 06:15 AM
falconey's Avatar
I'm talking tread width. The first number. If you're wheel is 8" then there is a certain minimum you have before your tire is strecthed. I don't know the minimum, but I don't think I'd run a 225 on an 8" wheel. Not saying you are running that because I don't know.
Mar 12, 2020 12:06 AM
Excalibur23
Oct 13, 2015 04:33 PM
Serotta33
Sep 17, 2015 12:14 PM
videomano
Sep 8, 2015 03:28 PM
