door hinges
Aug 26, 2005 | 04:10 PM
does anyone know if it is possible to move a hinge from the front door to the back door on the same side?
Aug 26, 2005 | 10:03 PM
Nope they are different! Bolt hole spacing aren't the same. Sorry dude!
Aug 26, 2005 | 11:50 PM
Quote: does anyone know if it is possible to move a hinge from the front door to the back door on the same side?
If u problem is sagging front door, replace the pin & bearing. Or put a thin shim under the lower hinge: loosen 2bolts, raise the door, put shims under both, tighten...
Aug 27, 2005 | 08:18 AM
my front door STICKS...and my trunk has a big "firecracker" sound when you close it lol
Aug 27, 2005 | 08:58 AM
Quote: my front door STICKS...and my trunk has a big "firecracker" sound when you close it lol
When it sags, it sticks. All ? b/c theres a stick in the B-pillar. When door is level, never touches the stick and wont stick...
Dont carry crackers, firehazard.
Aug 27, 2005 | 04:08 PM
My trunk makes that firecracker noisse to
Aug 27, 2005 | 06:40 PM
Quote: If u problem is sagging front door, replace the pin & bearing. Or put a thin shim under the lower hinge: loosen 2bolts, raise the door, put shims under both, tighten...
Do u have 2 remove the frnt fendr to get at dem bolts?
Aug 27, 2005 | 09:10 PM
Quote: Do u have 2 remove the frnt fendr to get at dem bolts?
No.
wtf is up with this 10 char min?
Aug 28, 2005 | 01:03 AM
allwayss depends dem bolds. open da door do checkout...
Aug 28, 2005 | 06:10 AM
How can I stop my trunk for sounding like a firecracker ......It's kind of noisy !!!
HELP!
Aug 28, 2005 | 07:00 AM
Quote: ...It's kind of ... HELP!
hlpuself: all hinges have a need for lubrication
Aug 28, 2005 | 05:31 PM
my rear doors have always seemed to stick, I just joke around and call anyone who cant slam them shut wusses
Aug 28, 2005 | 07:30 PM
Quote: hlpuself: all hinges have a need for lubrication
My trunk and many other maxs trunks have a poping noise when they are shut it has to do with the tennsion bars.
I have oiled them and fiddled with then with no luck
It is not simple oil that solves this (that I am sure of)
Thanks for any replys
Aug 29, 2005 | 12:36 AM
Quote: My trunk and many other maxs trunks have a poping noise ...
I guessed that, but still cannot hear the noise...
Take smtg to insulate the tensionbars, tst: wrap cloth, tape or any thin...
Aug 29, 2005 | 05:28 AM
If I took the tensinbars out and put in gas lift springs would it hurt anything?
Aug 29, 2005 | 11:13 AM
Quote: If I took the tensinbars out and put in gas lift springs would it hurt anything?
- wallet; 50$ hole
- installation; drillin into finger hurts.
- consequences; envious ppl would get ulcers
- effects; granma's chrystals brkdown under new assemblys
=DIY! ...then u have experienced tHat...
Aug 29, 2005 | 11:19 AM
the shocks that fit to hold the trunk up don't last very long. I replaced mine a few years back to gain more room under the rear deck for stereo stuff.
after about a year, those shocks would no longer hold the lid up. now every time I get in the trunk, I have to prop the lid up with a stick.
