Two Questions 00' I30
Old Aug 29, 2005 | 06:45 AM
falconey's Avatar
first:
has anyone replaced the positive battery terminal? It seems to be connected to 120A fuse so it's not just and snip it, strip it job that's why I ask. Any tips here would be awesome.
second:
can someone direct me to instuctions/tips for running the power line back to the trunk. for a temp fix I went under the car, but I would like to run it through the car. I just need a tip of what point to enter the firewall.
Old Aug 29, 2005 | 06:48 AM
falconey's Avatar
ok make it 3 questions....
will I have problems if I get a staggered setup with rims...
what I'm looking at is 19x8.5 front 19x10 rear with 35mm offset on both
thanks
Old Aug 29, 2005 | 01:23 PM
falconey's Avatar
thanks
ok well I think I found the answer to this question here, but if anyone else has anything else to add please do. It took me all day to find this, lol.
Old Aug 29, 2005 | 07:41 PM
i30ds's Avatar
Armed and Dangerous
first:
second:
1. buy a new battery
2. there is a factory hole in the middle of the fire wall which is plugged up. remove the rubber plug and then run your cable through it. after that, run it under the carpet, under both of the kick plates, and then pull the upper portion of the rear cushion and run the wire into the trunk.
Old Aug 29, 2005 | 07:43 PM
i30ds's Avatar
Armed and Dangerous
you also need to consider the bolt pattern and the hub bore size.
Old Aug 30, 2005 | 04:33 AM
falconey's Avatar
1. I have a redtop optima that I've installed. What I'm trying to do is put a beefier terminal on the positvie lead, but I don't know how to get around the fusible link. That's what I'm questioning.
2. I saw a few spots that are similar to what you describe. Do you have a pic of the area so I can narrow it down or is there a part that's near this area that could direct me to it?
Old Aug 30, 2005 | 04:37 AM
falconey's Avatar
Hub bore size I know nothing about, but I've already made the purchase and picked the wheels up yesterday.
I'm thinking this is going to be a pretty sick looking setup, or at least I hope.
Fronts will be 19x8.5 35mm offset, rears will be 19x10 38mm offset.
Thanks for the replies buddy!
Old Aug 30, 2005 | 04:42 AM
falconey's Avatar
the wheels I have, found them on ebay
http://cgi.ebay.com/ebaymotors/19-AC...QQcmdZViewItem
Old Aug 30, 2005 | 03:15 PM
i30ds's Avatar
Armed and Dangerous
Looks like they'll fit.
Old Aug 30, 2005 | 03:16 PM
i30ds's Avatar
Armed and Dangerous
Sorry, no pic.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
uttadms31
Sep 30, 2015 05:24 AM
Socalstillen
Sep 26, 2015 12:01 PM
