HID install: high beam indicator always ON
my friend installed a HID kit and its successfully operational. its as 00-01 5th gen. the high beam indicator light is always ON the instrument panel now. any suggestions/experience with this?
did he splice wires or just plug and play? because i've installed probably the hardest conversion HID high beam and low beam system from an H4 and i made it work liek a charm. lemme know and i'll try to help.
its a McCulloch kit, and theres two wires (white/black) from the ballast that you fit into a 3 prong plastic connector that goes to the bulb back itself.
those are the only wires that needed connecting..
hm
thanks not really sure what it could be. we'll brainstorm a little more
hm
thanks for the input scmaxima2k. ive had a hanabi kit on my 4th gen Plug/play with no prob like that.
i dont think this is a real "problem" just annoying.
well if anyone else has seen anything like this and can tell me its normal. thats cool. in the meantime i ll let my friend know. thanks
It's not normal, you have a wire cut in wrong, most likely the ground. Go back over the install. On both left and right headlight plugs, the black wire is ground and power should come from the middle wire. Both left and right sides tap into wires in the exact same positions on the plug.
with my friends H4 for his Si, we had to actually switch the prongs (the plugs that are color coordinated) so that it doesn't match. for example, if it is suppose blue with blue, and red with red, it would actually go blue with red. try that, because sometimes the factory does it wrong. after that his system worked. give it a shot and let us know.
My roomate had a single beam H4 plug n play kit on his 00 maxima and encountered the same issue with the high beam indicator on and I know other people who have had the same thing happen with other single beam kits. I had a high/low plug n play kit on my 00 maxima for a bit and my indicator wasn't on... I thought it was normal for a single beam plug n play kit...sorry
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
