Re: Wheel Spacer Decision
Old Sep 1, 2005 | 08:44 AM
jay23's Avatar
Hello guys i am finally getting a set of H&R spacers for my 02 maxima. Now, i cant decide what size to get. I want to even out my rear tires to my fronts would a 15mm be enough or should i go with 20mm.
Old Sep 1, 2005 | 03:07 PM
jay23's Avatar
Also, can you tell me the right wheel stud for my car. Dont know if its 14.25 or 12.85?
Old Sep 1, 2005 | 05:37 PM
Ammi's Avatar
350 Detroit Muscle
depends on how wide your wheels are too
Old Sep 1, 2005 | 06:19 PM
jay23's Avatar
i am using my stock wheels
Old Sep 1, 2005 | 06:20 PM
Ammi's Avatar
350 Detroit Muscle
ah. You can use 20mm
Old Sep 1, 2005 | 06:50 PM
jay23's Avatar
cool so a 20mm spacer would be the ideal size. Would 20mm align in my fronts
Old Sep 2, 2005 | 03:47 AM
Ammi's Avatar
350 Detroit Muscle
I would use 20mm only for the rear
Old Sep 8, 2005 | 01:13 PM
NISMAX03's Avatar
I had H&R 20mm spacers on the rear and 15 mm spacers up front with 235/45/17 tires on OEM TE rims (45 mm offset). Both front and rear wheels were flush with the fender.
Old Sep 9, 2005 | 08:11 PM
jay23's Avatar
hey guys i finally got my spacer its not H&R but its Eibachs Pro Spacers. If you guys are interested the part # 90.4.20.003.4 the size is 20mm i got mine at WheelWarehouse Tel # 714-772-1281 and talk to Jason ext# 5126. The Spacers that i bought came with its own studs so its just a simple bolt on
Old Sep 10, 2005 | 12:03 AM
OOmaxSE's Avatar
how much you pay for it? i'm thinking of either 20mm or 25 mm in the rear. some say that you can squeeze another 5mm to their 20mm spacers in the rear, making it a 25mm spacer. 10mm in the front is ideal
Old Sep 10, 2005 | 01:29 PM
Triple8Sol's Avatar
I miss the .org!
Are you putting them on the stock rims? If you're going aftermarket, I'd suggest just getting rims in correct offsets for your application...
Old Sep 10, 2005 | 04:05 PM
jay23's Avatar
OK now that i finally got the spacers done on the rear of my car, do you think that its neccesary to get a set of spacer to the front wheels. I am thinking 5mm to 10mm.
Old Sep 11, 2005 | 06:03 PM
OOmaxSE's Avatar
10mm for fronts.
Robert Schneeweis
Jan 11, 2017 06:47 PM
lrb6805
Sep 30, 2015 08:12 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
