quick question about rims???
Old Sep 7, 2005 | 04:57 PM
krmaxima's Avatar
will these fit??? 18 x 7.5 and bolt pattern is 5 X 108.offset +42
Old Sep 7, 2005 | 05:03 PM
upstatemax's Avatar
no, our bolt pattern in 5x114
Old Sep 7, 2005 | 07:32 PM
krmaxima's Avatar
so there is no way of making them fit correct???
Old Sep 7, 2005 | 07:41 PM
krmaxima's Avatar
also does this mean that other bolt patterns will not fit???
Old Sep 7, 2005 | 08:25 PM
krmaxima's Avatar
also what about offset what does that have to do with rims. Im sorry if its stupid question. And will other sizes fit???
thanks
Old Sep 7, 2005 | 08:29 PM
irish44j's Avatar
retired moderator
Offsets that will fit: 45mm (stock-ish) to 30mm (flush with sides of wheel wells). The offset is how far out the wheels comes, and determines if the wheel will fit in the wheel wells and clear the brake calipers.
Bolt patterns that will fit: 5x114 (and no others)
I suggest you check out the wheels&tires forums, and read the STICKIES up at the top of them for explanations of bolt pattern, offset, etc...
irish44j's Avatar
retired moderator
that is precisely what it means
Puppetmaster's Avatar
thanks
Here ya go:
Originally Posted by msoemax
Offset is a measurement for where the mounting of the wheel will be in reference to the outer or inner edge of the wheel. As see bellow in the diagram a FWD wheel is mounted at the outside of the wheel(Flush), where as a RWD wheel is mounted in the center or all the way in, thus making the wheels stick out a bit.
And anything other than 5x114 will not fit.
Old Sep 7, 2005 | 08:39 PM
maximillien's Avatar
anyone has a problem with the stock front hub? I think it makes our wheels in the front sticks out a bit while the rear is PERFECTLY flush?? I did this with stock 17" wheel...anyway to fix this besides grindin the hub in the fronts down?
Old Sep 7, 2005 | 08:44 PM
krmaxima's Avatar
thank you so much you have answered almost everything last question i have is is 5x114.3 the same thing as 114?????
Old Sep 7, 2005 | 08:45 PM
irish44j's Avatar
retired moderator
you cannot grind the hub down. The solution is to get 15mm spacers for the rear wheels to even it out. The only way you can bring the front wheel "in" would be to get wheels with a higher + offset (50, perhaps)...but then you may not clear the brake caliper.
irish44j's Avatar
retired moderator
yes.
10char
Old Sep 7, 2005 | 09:14 PM
MaxBoost925's Avatar
Drug Money
LOL, i guess offset wheels are not for our FF max's huh?
Old Sep 8, 2005 | 03:11 PM
irish44j's Avatar
retired moderator
I think you mean "staggered" not "offset"
They will work fine on a FWD car, but you won't be able to rotate them, that's all....
Old Sep 8, 2005 | 09:46 PM
sooner02r1's Avatar
And buy working fine, Irish means, they will look SICK.
Old Sep 9, 2005 | 08:17 AM
KCMC582's Avatar
i really wanted to get staggered Hiros for my car, since the rears would look really badass, but then obviously i would never be able to rotate tires, which kinda sucks, and also anyone in the know would ask why i did that to a front wheel drive car.
Old Sep 9, 2005 | 08:38 AM
ChromeSE5's Avatar
i'd just get some spacers for the rears... small ones to compensate for the fact that the rears stick in a little bit more than the fronts.
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
Johnny9595
Sep 3, 2015 05:18 AM
