quick question about rims???
Offsets that will fit: 45mm (stock-ish) to 30mm (flush with sides of wheel wells). The offset is how far out the wheels comes, and determines if the wheel will fit in the wheel wells and clear the brake calipers.
Bolt patterns that will fit: 5x114 (and no others)
I suggest you check out the wheels&tires forums, and read the STICKIES up at the top of them for explanations of bolt pattern, offset, etc...
Originally Posted by krmaxima
also what about offset what does that have to do with rims. Im sorry if its stupid question. And will other sizes fit???
thanks
thanks
Originally Posted by msoemax
Offset is a measurement for where the mounting of the wheel will be in reference to the outer or inner edge of the wheel. As see bellow in the diagram a FWD wheel is mounted at the outside of the wheel(Flush), where as a RWD wheel is mounted in the center or all the way in, thus making the wheels stick out a bit.
anyone has a problem with the stock front hub? I think it makes our wheels in the front sticks out a bit while the rear is PERFECTLY flush?? I did this with stock 17" wheel...anyway to fix this besides grindin the hub in the fronts down?
Originally Posted by MaxBoost925
LOL, i guess offset wheels are not for our FF max's huh?
They will work fine on a FWD car, but you won't be able to rotate them, that's all....
i really wanted to get staggered Hiros for my car, since the rears would look really badass, but then obviously i would never be able to rotate tires, which kinda sucks, and also anyone in the know would ask why i did that to a front wheel drive car.
03-12-2020 12:06 AM
