With Tein-S
With Tein-S
Hey guys im getting the AGX's on Tein-S and can you please tell me what i need to buy to get the alighment with no problem's,because as i know tein-S
is a 2.2front and 1.8rear so i just wanted to know what else i need to get to make the allighment easy any help is appreciated
Thnx Steve
Thnx Steve
I'm on STechs and my alignment was fine. You may want to pick up a camber kit Just in case. I bought one when I did my suspension and ended up not needing it. I have it for sale cheap if you want it shoot me a PM>
I also am about to S-tech AGX it, when my paycheck comes in. Did you purchase the camber bolts from tire rack? the 1 degree bolts? I wonder if I'll need them also, but it would be better to have them and not need them than the other way around.
How much shipped? If speedy doesnt want it.
i got tein stechs with the agx setup. my camber was off after installation but not by much! but at the same time i got my camber bolts installed for free cuz of "miscommunication" between the service writer and mechanic. so i paid $112 for 3yr alignment and freeeeeeee camber bolts with install.
as for where to buy the bolts....go to tire rack they have em.
F**k it. I will install my s-techs without camber bolts if It turns out I need the bolts I'll order them, my tires are shot anyway and I have new ones waiting to go on. I cant be that out of spec.
Originally Posted by SpeedyMaxima
Thnx Alot guys can you tell me the difference between camber plates and bolts?
Thnx Steve
Thnx Steve
Camber plates mount on top of the strut, makes changing the camber much easier and I believe you'll have up to a 4 degree +/- to play with. But all camber plates I've seen for the 4th gen max were priced very high.
wow, so many s-tech threads. i have heard that some people need more than 1 degree to get back into spec with s-techs. why does it vary so much from car to car? if you install the same suspension parts, wouldn't the change be the same?
EDIT: i guess if some OEM suspension parts are bent or worn would change things, right?
I believe basically bent parts is what leads certain people to needed camber bolts. After so many years and depeing on how harsh of roads that max has faced could have bent certain suspension parts that will throw off factory spec alignment.
In one thread about 3 people didnt need camber bolts, but I've read a few that do. I myself and going to not purchase camber botls and see if I needd them when I get my alignment, One new control arm will be going on the car so in a way this could be kind of a test. If I do end up needing it, tirerack ships fast 2day air for a good price so I wouldnt have to wait long for the bolts to come in.
Sweet. I will PM you at the end of the week. I'm going to install without camber bolts and see if I will need them, if so I'll pm and paypal you with the quickness if you can ship out saturday (going to try and drop it friday night after work)
Im on AGX/Tien S-techs. I compared it to another .org member's car in person that was on Progress/Illuminas, and they were about the same. All you need to do is take it for an alignment after install and that is it.
Lumberg™
Jan 24, 2005 03:38 PM
