AFR gauge Installed... yay
Old Sep 10, 2005 | 08:45 PM
Hind
I got a custom Air\fuel ratio meter installed, toook 4 hours but works good (looks like a flat black box with like 10 colored led's on it). Was wondering if other people had the same results, im not sure how these are supose to behave. It sits at the normal N\A but im curious when i hit the gas it jumps real fast (fast enough where i can see it go up) to Full Rich... now does that mean that i have fuel not being burned? after i lift off the gas, it takes a second but then it drops back down to the NA range (yelow). Did the people with this gauge have the same resutls?
Old Sep 10, 2005 | 10:07 PM
Anarchist's Avatar
I really miss the point of putting time and money into something like this. Even if you were (or are) racing, what good would the knowledge of your air/fuel ratio give you?
Old Sep 10, 2005 | 10:43 PM
Hind
I have had it from my last car but never installed it. i was bored so i did. thanks for being a retard.. DAARRRRRRR
Old Sep 10, 2005 | 11:12 PM
frankd121's Avatar
those things aren't even that accurate. if you want accurate afr readings, you need a wideband o2 sensor.
Old Sep 10, 2005 | 11:20 PM
Hind
would a wideband o2 sensor replace the one thats in there? srry , im new to this stuff...
Old Sep 10, 2005 | 11:41 PM
steven88's Avatar
Need A Light?
correct me if i am wrong...isn't the gauge he's running a narrowband? meaning narrowbands will only tell u if u are richer or leaner from 14.7 AFR and nothing more, compared to a wideband that tells u exactly wut AFR u are at?
Old Sep 11, 2005 | 08:21 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
someone needs to do their homework. this gauge he is talking about is most likely narrowband and wont tell you much. wideband would be the way to go or go to a dyno with an AFC and do some tuning. a/f is extremely important to the power and overall running condition of the motor.
Old Sep 11, 2005 | 08:40 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
There is my wideband 02 sensor, which helps me tune the most out of my slow 3.0L.
Old Sep 11, 2005 | 09:13 AM
Ephraim's Avatar
^^ what brand is that??
Old Sep 11, 2005 | 09:40 AM
PLX Devices Uses a trusty Bosch 5 wire 02 sensor, that can be purchased from VW dealerships for around 40 bux.
Old Sep 11, 2005 | 10:39 AM
chr0nos's Avatar
you got a wideband o2 sensor for $40?
Old Sep 11, 2005 | 08:41 PM
No, you can buy a REPLEACEMENT wideband 02 sensor- just the sensor itself for 40 dollars when its time for a new one. I have mine on all the time with the car on, and I haven't noticed any degradation in performance or response in the last 6 months that it has been in my car.
Old Sep 12, 2005 | 07:01 AM
chr0nos's Avatar
right. so you went to a vw dealer and asked for a wideband o2 sensor? i thought these were car specific, at least manufacturer specific. are they universal like the apexi safc?
Old Sep 12, 2005 | 11:50 AM
spiromax's Avatar
Seoul Man
The device you see installed in BlackBIRDVQ's car came from PLX Devices.
The device uses a Bosch 5-wire O2 sensor to get its readings. If you have to replace the sensor, you can pick it up for around $40. VW dealerships sell them, but that's not the only place to buy one.
Old Sep 12, 2005 | 01:00 PM
ColdSHO's Avatar
seems like the actual units are running round the $300 range, not bad
Old Sep 12, 2005 | 03:38 PM
BewstAdd1ct's Avatar
you can get a 2 1/16" gauge in white or black face with a w/b o2 for $300ish, or less if youve got a hook.
n/b o2 a/f gauges are just a light show.
Old Sep 13, 2005 | 06:44 AM
chr0nos's Avatar
wtf? regular oem replacement o2 sensor is about $60-150. How do you get a wideband for $40?
are they cheaper by design, or am i retarded?
Old Sep 13, 2005 | 02:41 PM
I have no idea why the narrow band 02 sensors used in our cars are so expenssive. Don't ask me I am not the one who designed and manufactured these things. Ask Bosch, they are the ones who make 02 sensors for our cars, and 80% of the world.
Old Sep 13, 2005 | 05:48 PM
materials used, construction, etc...
the internal design is quite a bit different...
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
