Dyno Discussion and Slips Discussion and a moderated "Dyno Slips" sub-forum to allow for posting of dyno slips.
Can transmission problems affect Dyno #'s?
Old Sep 11, 2005 | 08:18 PM
AsthmaMax11's Avatar
Could messed up bearings, synchros, etc. affect the Dyno #'s you're putting to the ground?
How about a bad MAF?
Old Sep 12, 2005 | 06:33 AM
NmexMAX's Avatar
dot dot dot ...
Bad maf yes .. synchors/bearings not likely.
Old Sep 12, 2005 | 01:52 PM
tavarish's Avatar
fwd gone rwd cr00
slipping clutch?
Old Sep 12, 2005 | 02:50 PM
Originally Posted by tavarish
slipping clutch?
no my clutch is good.
I might have asked an obvious question but right now I am out of answers on why my car is down about 20 whp and 15 wtq.
Old Sep 12, 2005 | 02:57 PM
NmexMAX's Avatar
dot dot dot ...
My guess is it's not tranny related.
ECU/electronics could hamper this easily.
CHeck compression ( long shot I know)
Old Sep 13, 2005 | 07:53 AM
Yeh compression might be an issue but the motor has less than 50k on it and I've regularly changed the oil.
How would I be able to tell if it was an ECU related problem?
Old Sep 15, 2005 | 06:23 AM
s0ber's Avatar
Where is teh link to your graph? I cant seem to find the damn thing anywhere :-\
Old Sep 15, 2005 | 07:14 AM
NmexMAX's Avatar
dot dot dot ...
I wasn't saying the ecu is bad, just it might be retarding timing screwing with a/f etc due to a bad sensor or bad sensor reading.
Old Sep 15, 2005 | 10:59 AM
http://forums.maxima.org/showpost.ph...2&postcount=58
Yeh the main reason I'm saying that the #'s are off is because before my JWT ECU and MEVI I was hitting about 180 whp and 190 wtq.
Yeh I put in 2 brand new O2 sensors and 1 partially new one (50k on it or something) and my Knock Sensor has about 50k on it as well. I am not pulling any codes with the stock ECU but I pull like 4 with the Jim Wolf in there.
Whenever I check for codes I go to Autozone and they have an OBD-II scanner or something that does it, is there a more efficient way?
Old Sep 15, 2005 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
Hmmm, maybe when you have the JWT in there it gets a bit wacky because it's reading for a 95/6 in a 98.
Try racing bijan wit stock ECU ... And what 4 codes does it pull? (Sorry if it has been posted)
There's a 'different' way other than AutoZone OBD-II to check for them, do the ecu turn screw method outlined in the 4th gen FAQ's.
Old Sep 15, 2005 | 02:37 PM
Check out my graph. The top line is with the JWT ECU and the bottom is with the stock ECU. You can see that I'm only getting gains so I am almost positive that the JWT ECU is doing it's job.
I should apologize for not posting my codes in the first place.
Here they are:
P 1605 ?Keep alive memory test failure?
P 0136 O2 Sensor 2 in Bank 1
P 0400 EGR code (this one sort of worries me, but I only get it with the JWT in there....)
P 1220 Series throttle control system malfunction?
Yeh I've done the ECU screw turn thing but I can't follow the blinking very well.....
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
