what size rim to get????
Old Sep 14, 2005 | 09:22 PM
krmaxima's Avatar
well i dont know too much about the different sizes of rims that will fit and look good on a 03 maxima. WHat i want to know is what size is good. im looking into 18 or 19. All i know is that our bolt pattern is 5x114 so what width and what offset should i get
thanks
Old Sep 14, 2005 | 10:11 PM
VIP Maxima
u want show? go 19. get anywhere from 8-9" width
u want performance, go 17's and get anywhere from 7-9" width. offest depends on ur rim. im on 19x8 +40
Old Sep 14, 2005 | 10:17 PM
Bonka's Avatar
Schnell kaputt
I'd go staggered on the 5.5 gen.
8.5" front 9.5" rear. An offset like +30 would look good, flush with fender.
Old Sep 14, 2005 | 10:49 PM
krmaxima's Avatar
the prob with staggered is that u cant rotate the tires?? im looking for both performance but more for looks .
also 98mike are your rims all the same size and all the same offset???
Old Sep 15, 2005 | 08:18 AM
Bonka's Avatar
Schnell kaputt
Actually most people get staggered setups on FWD for looks
Old Sep 15, 2005 | 11:03 AM
tripleGmax's Avatar
if you dont go staggered on a fwd car for looks especially our maximas, what on earth are you doing it for?? the front tires are th e ones moving and turning the car
Old Sep 15, 2005 | 01:36 PM
VIP Maxima
yeah all 4 are 19x8 on 245/35 with +40
Old Sep 15, 2005 | 02:54 PM
falconey's Avatar
A staggered setup on fwd does help with handling. A wider rear wheel than front wheel helps the tail of the car when cornering. It definitely doesn't hurt anything to go staggered on a fwd car.
Old Sep 23, 2005 | 09:49 AM
krmaxima's Avatar
well this fit??????????????/
Wheel features:
* 20"x9"
* Silver
* 3" polished lip
* 5x114 lug pattern
Tire features:
* Toyo Proxes 4
* 245/35/20 ZR
Old Sep 23, 2005 | 02:15 PM
Ice Train's Avatar
What about a 2000? I want looks but not sacrificing too much performance.
Old Sep 28, 2005 | 04:53 PM
BRAN808's Avatar
I'd go with 18's. Look for something 8"-8.5" wide with approximately a +35 offset with 235/40/18 tires. These specs are pretty common with 5th gen guys. Of course they are all "general" specs. You could go wider, with lower offsets, and wider tires, but depending on suspension setups and road conditions, and so on and so forth, you may run into some problems. 18x8, with a +35 offset, with 235/40/18's you should be fine either way!
Old Sep 28, 2005 | 05:01 PM
tripleGmax's Avatar
ok i have no idea where youre pulling this from, but its basic knowledge (i think) that wider tires/rim on the back of a fwd car is going to create understeer, so when you think you are turning youre gonna head straight for a tree/guard rail or whatever. rwd cars with high hp/tq do it for the simple fact that it controls the rear from swinging out so much.
however, if you put wider rims/tires up front on a fwd caryoure gonna create oversteer and could be considered good in some cases like autoX or whatever.
but my point is a staggered setup like you suggest does hurt on a fwd car.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
knight_yyz
Nov 1, 2015 01:34 PM
