egr and coolant lines vi swap
You can either plug the TB coolant lines, or you can get a hose splice and close the loop.
For the egr, all you have to do is disconnect the vacuum line at the egr valve and it will stay shut. Plug the vacuum line so you don't end up with a leak when the egr vacuum solenoid opens.
Originally Posted by mad-max98
what about emissions when i go back to cali next year
non of my vacuum sources is for my egr on my vi setup "as far as i know" ,, i only did the necessary vacuum lines and the egr still lets gas through,,where is that egr vacuum supposed to hook up anyways
By removing the EGR system I mean removing the whole thing. Not just the guide tube. I'm talking like pull all that crap off the block and head and plug the hole in the back manifold.
Originally Posted by MAXimumHP
Broaner,
Doesn't that just freak the ECU out because all those connectors are unplugged?
There is supposed to be some resistor you can use to give the ECU the correct reading but haven't found much info on it. I don't throw an EGR code very often with mine removed, hasn't affected performance any.
Broaner,
Originally Posted by scrhale
I am pretty sure when you block/remove/tinker with EGR it makes you run slightly rich unless you have SAFC ... just to let you know.
Originally Posted by Broaner
The EGR is only used on part throttle. So, if it does make you richer it doesn't matter because its not happening when you're trying to make power.
So we have to bypass the coolant lines thru the TB in order to do this?
I bypassed this line just for fun on my stock IM, cause i figured it would help provide some cooler aire in my IM (i was down there and i wanted to give it a try). I come to find out a day or so later that my idle was tripin out, it would get stuck in cold start and keep the idle at 1400~ RPMs like if i just started it, but the motor was at op. temp.
It would only happen on cold nights when i drove on the freeway, i would notice when i would get off the freeway and come to a stop, cause my idle would be retardedly high...
After i routed the coolant line back to stock (thru the TB and back of USIM (95)) the problem went away completely. Would i have to do the same thing with this setup? I guess there is a sensor there to read coolant temperatures to start cold start idle. I just dont want to run into that problem again, it was SUPER ANOYING...
hmm, I haven't run mine in the winter yet, but I live in WI, so I will when it gets cold. There is an entirely mechanical device in the TB that pushes on the throttle plate when it's cold. You would need to see if you can adjust this mechanism. I'd have to look closer at that to see how it works. Otherwise, yeah, you would need to run new lines to the TB.
The 4th gen throttle body has a fast idle cam that cracks the throttle open a little bit and then retracts as the coolant warms up the throttle body. What you needed to do was adjust the fast idle cam so that it didn't open the throttle when cold. Of course you would have then had the opposite problem of a low idle when cold until the engine warmed up.
I looked when I went to lunch and it is adjustable by a nut on the end of a threaded shaft. Not sure if you could find a happy median there or not. I'll find out this winter
I have heard of this fast idle cam however i dont know where it is nor how to adjust it...
Can anyone post pics of this adjustment screw and possibly what to do to adjust it?
shilov
Feb 19, 2024 09:40 PM
97_GXE
20
Sep 17, 2015 08:12 PM
