Is a 95ECU on a VQ35 still the way to go?
Due to some other unrelated things this summer, my VQ35 project took a back seat.. Those things are getting finished, so I will be back on the project real soon.
I am just wondering, is the best method to get the VQ35 running still to reconfigure the engine to run on the 95 ECU? Or has someone come up with a method to keep the variable cam stuff?
Thanks.
Thanks.
Originally Posted by scrhale
I didn't know you had to do any reconfiguring of the ECU to get it to run a VQ35.
Originally Posted by motocross416
Are you sure you're willing to do the work for this swap if you won't even research it. It takes about 30 seconds to find this out even using the free search
Keep in mind, I am NOT doing a conversion on a Maxima. Much of the information is irrelevant to my project. I only need to get the VQ35 running at optimum performance.
Originally Posted by Stephen Max
Optimum performance requires operating VCT and VQ35 ignition timing, which means ecu and engine harness along with the engine.
My project only uses the engine itself. I have no other nissan components.
There is a way to get it working. Some one posted up about it not too long ago. It wasnt a full rewire.
http://www.forums.maxima.org/showthr...light=painless
I have read many threads/posts and no where is it mentioned that you have to manually disable VTC or tinker with the TB. I was thinking of tossing the 00-01 TB on there if I did the swap. Is this not smart?
I never understood why you have to mod the 02 TB? Is it because of that whole drive-by cable/wire . I don't know what those mean. Anyway ... I thought with Spaces, redrilled CAMS, and 3.5 TB to Headers you are good to go.
To restate the obvious ... is ECU work only required for pulling optimum performance?
