Brakes!!!!!
Old May 28, 2001 | 06:07 PM
sbmax95's Avatar
I was changing my brakes this afternoon and ran into a problem with the left rear. The piston in the caliper would not depress enough to put the caliper(with the new pads) back on. I tried to bleed the line to relieve some of the pressure but that did not work either. The only thing I could see out of ordanary was that the inside pad was wearing at a slight angle(10 degrees or less) Does anyone have a clue? Please let me know anything. THANKS!!!
Old May 28, 2001 | 06:14 PM
Ravq's Avatar
The rear pistons are the type that must be rotated in a clockwise manner to get them to depress to make room for new pads. Unlike the front pistons which can just be spread. The slight angle might just be from the pad being improperly seated?
Old May 28, 2001 | 06:41 PM
sbmax95's Avatar
Thanks for the tip. Do you know of any special tool needed to do that properly?
Old May 28, 2001 | 06:44 PM
Ravq's Avatar
Yes they do make a special tool to rotate the piston but just a regular set of needle nose pliers will do the job.
Old May 28, 2001 | 06:52 PM
sbmax95's Avatar
Thanks alot man!!
Old May 28, 2001 | 06:54 PM
Ravq's Avatar
Thanks alot man!!
No problem!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
