What is the stock timing advance with stock ECU on a 4th Gen
I saw that but I think I was looking for of a true value (and not the store).
My car with the stock ECU read a value of 44 degrees @ 6500 rpm. Is it correct, I don't know.
This is with digimoto software.
My car with the stock ECU read a value of 44 adv @ 6500 rpm. Is it correct, I don't know.
Can anyone compare the difference between what the stock 4th gen ECU runs and what the stock 5.5 gen ECU runs? I'd really like to see how much more timing 5.5 gens run compared to ours.
My data in post #2 above is all at WOT.
I get 44-46 deg at part throttle cruise over a wide range of rpm (<2000 - 5500). As soon as you put your foot into it and start to accelerate, the advance starts to drop.
Gotcha. I thought something was wrong. That's what I noticed this morning on my way to work with Scantool Software and Digimoto. When I let up the timing went up to 43 degrees. On acceleration in would hang around the 25 degree mark.
Originally Posted by JClaw
Mine also hanged around 25 degrees.
Originally Posted by nismology
That's odd. Deezo you have a TS ECU and JClaw has a stock one yet the WOT advance values are around the same.
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
