quick psi air pressure question
Old Oct 6, 2005 | 02:37 PM
aw89maxSE's Avatar
I looked at my tires and I thought they were a little low and so I filled them up and now. I noticed the tires were extremely stiff so I took my little electronic PSI thing and it said I had 85 in there, but the tire says max load 50PSI. Now I know I am going to do the obvious thing and take some out but what do you guys usually ride on considering your recommended PSI?
Old Oct 6, 2005 | 02:43 PM
90pearlSE's Avatar
I run my tires around 32-35psi.
Old Oct 6, 2005 | 02:45 PM
tripleGmax's Avatar
i run at 37, 38. i would imagine your guage is broke, it would take forever to fill it up to 85 if it didnt blow up!
aw89maxSE's Avatar
what size tires do you though (not sure how much it matters )
Old Oct 6, 2005 | 02:47 PM
90pearlSE's Avatar
Mine are 215/60/15
Old Oct 6, 2005 | 02:50 PM
tripleGmax's Avatar
235/40/18 i dont think it matters i think recommended is 32?
Old Oct 6, 2005 | 02:51 PM
tripleGmax's Avatar
Originally Posted by 90pearlSE
Mine are 215/60/15
ya know thats wrong.....205/65/15 is stock.
Old Oct 6, 2005 | 02:56 PM
aw89maxSE's Avatar
I am running those same tires and i just checked the pressure with the old school gauge(measures in lbs) that pops out and that thing went out as far as it could. I guess I was wrong in thinking it needed air.
Old Oct 6, 2005 | 02:58 PM
MrGone's Avatar
smaller tires tend to mess with you lol
oh and
Old Oct 6, 2005 | 03:05 PM
90pearlSE's Avatar
I have stock rims....so what's the big deal? Just went a little lower and wider, the rims can take that size no problem....
Old Oct 7, 2005 | 09:31 PM
maximal's Avatar
i did the same...tires cost a little bit more but they look way better than stock. you just have to take into account the 2% difference when trying to compute speed and mpg.
Old Oct 7, 2005 | 11:30 PM
djx82's Avatar
standard PSI is 32~35... but try 32... and you are lucky that it didn't burst on you at 85, cuz if it DID.... it wouldn't be funny man.. you would have no face~~MORE likely turn into the guy in the "HELLRAISER" movie..
Old Oct 8, 2005 | 04:53 PM
maximaboi's Avatar
thats nothing. when I was working for valvoline I had a woman come in with a 90 camry. stock steel rims with hub caps. she had 95PSI in all 4 tires! I couldnt beleve it so I got another gauge and that one also showed 95PSI. I guess she went to a gas station and put as much air as the compressor would allow in. I have no ideah how she didnt blow every tire off of that car.
Old Oct 8, 2005 | 06:08 PM
internetautomar's Avatar
mod or sell?
actually I've seen dealers do that on used cars.
not sure why though it kills the ride, but it will help mileage at the expense of safety and tire life.
Old Oct 9, 2005 | 08:09 AM
maximagxe90's Avatar
i have stock tires size,
and the psi on them are 44,
so i don't see any 32-35 anymore,
it mostly 40-44 psi,
Old Oct 9, 2005 | 09:42 AM
Wiking's Avatar
Used tire pressure is USER / tire dependent, load dependent, speed dependent, temp dependent. When all variables are at highest level, pressure has to follow.
No load, No speed, No Temp ...my citydrive wheels are soft and comfy, wear evenly ---> My tire pressure: 2 bars. http://www.sciencemadesimple.net/pressure.php
Nissan Handbook: "Look at center console located sign." ?? Meee... still trying to locate THE Nissan Center Console. Can u tell where it is?
Look at your Tires, Manufacturer Info:
Continental 15" sidewall says: Max pressure 44psi
Michelin 15" sidewall says: Max pressure 51psi
Note: Only Maximum pressure is indicated on the tire sidewalls. No recommendation for normal daily drive.
Old Oct 9, 2005 | 09:45 AM
Wiking's Avatar
Originally Posted by maximagxe90
... mostly 40-44 psi,
U must be driving all the time over 120mph with 5 persons, trunk full, at 120F ???
rbuswell
Nov 17, 2016 04:54 AM
Maxboy23
Sep 8, 2015 06:53 PM
02nissmax
Sep 5, 2015 01:50 PM
soloist3
29
Sep 1, 2015 03:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
