quick psi air pressure question
I looked at my tires and I thought they were a little low and so I filled them up and now. I noticed the tires were extremely stiff so I took my little electronic PSI thing and it said I had 85 in there, but the tire says max load 50PSI. Now I know I am going to do the obvious thing and take some out but what do you guys usually ride on considering your recommended PSI?
Originally Posted by tripleGmax
235/40/18 i dont think it matters i think recommended is 32?
Originally Posted by 90pearlSE
I have stock rims....so what's the big deal? Just went a little lower and wider, the rims can take that size no problem....
thats nothing. when I was working for valvoline I had a woman come in with a 90 camry. stock steel rims with hub caps. she had 95PSI in all 4 tires! I couldnt beleve it so I got another gauge and that one also showed 95PSI. I guess she went to a gas station and put as much air as the compressor would allow in. I have no ideah how she didnt blow every tire off of that car.
Used tire pressure is USER / tire dependent, load dependent, speed dependent, temp dependent. When all variables are at highest level, pressure has to follow.
No load, No speed, No Temp ...my citydrive wheels are soft and comfy, wear evenly ---> My tire pressure: 2 bars. http://www.sciencemadesimple.net/pressure.php
Nissan Handbook: "Look at center console located sign." ?? Meee... still trying to locate THE Nissan Center Console. Can u tell where it is?
Look at your Tires, Manufacturer Info:
Continental 15" sidewall says: Max pressure 44psi
Michelin 15" sidewall says: Max pressure 51psi
Note: Only Maximum pressure is indicated on the tire sidewalls. No recommendation for normal daily drive.
02nissmax
09-05-2015 01:50 PM
MaximaDrvr
08-19-2015 08:20 PM
