Radiator Flush Procedures Needed Immediately
Hi was was changing the coolent on my radiatory and was wondering which hose do i take off inorder to drain all the coolant? I want to do a complete flush because it has 70k miles on it.
fill radiator with water
start engine and run to operating temp (to open thermostat)
leave engine running
remove drain plug
let car run till nothing else comes out
turn off car right away
Originally Posted by JUICED
Another alternative to removing all the old coolant out is to remove the drain plug from the block!
If you want to get technicial we can
: The following instructions are provided in the Maintance section of the NISSAN Service Manual on pages MA-14 & MA-15. In particular "YOU" can read #4.
1. Set air conditioning system as follows to prevent coolant from remaing in the system.
a. Turn ignition switch ON and set temperature controlloer to maximum hot position.
b. Wait 10 seconds before turning ignition switch OFF.
2. Open radiator drain plug at the bottom of radiator, and remove radiator filler cap.
3. Remove reservoir tank, drain coolant, then clean reservoir tank.
4. Remove drain plugs on both sides of cylinder block and air relief plug.
5. Check drained coolant for contaminants such as rust, corrsion or discoloration. If contaminated flush engine cooling system, refer to "FLUSHING COOLING SYSTEM", MA-16
: The following instructions are provided in the Maintance section of the NISSAN Service Manual on pages MA-14 & MA-15. In particular "YOU" can read #4.1. Set air conditioning system as follows to prevent coolant from remaing in the system.
i have a service manual too but never thought it was necessary to use it when flushing my coolant. i was smart enough to figure it out myself
you do it that way...i'll do it my way that is easier (which is why most people use this method)
oh, i know your method is the most commonly used method of which i also use and others in my nissan dealership use, but you mentioned that draining the block wouldn't completely drain your coolant which is "wrong." i may be a new member to this forum, but than again i think i have more experience working on all nissan's than you. have a nice day!
Originally Posted by soonerfan
look at the newbie who is smart just because he can read a service manual. now can you actually go out to your car and find them?
I do it your way too
you dont remove a hose. you remove the plastic drain plug from the bottom of the radiator. if you also want to remove all the coolant still in the engine block- replace drain plug
remove drain plug
remove drain plug
Wont this cause air pockets when you fill up the system again?
CorollaULEV
30
Aug 9, 2021 08:11 PM
TonyJr
Aug 20, 2015 12:14 AM
