HELP: Car shuts off when I come to a stop
Old Oct 11, 2005 | 02:39 PM
cefiro a32's Avatar
My car has been randomly shutting off. When I come to a full stop and then begin to accelerate the rpms drop and the car turns off. The only code I get is 05 05 which means no problem is recorded. I just replaced the ks but that didnt seem to help. I have also tried cleaning my TB, cleaning IACV, and changing pcv. None of this seemed to help. Please help.
Old Oct 11, 2005 | 03:53 PM
NLK's Avatar
NLK
Most likely a sensor problem, had a problem like this before. Ended up being the coolant temp. sensor
Old Oct 11, 2005 | 05:20 PM
gto400no1's Avatar
could try cleaning the egr valve, my buddy ran into a similar problem last week. all we did was clean his egr and his truck ran like a champ again.
Old Oct 11, 2005 | 05:32 PM
95MaxTampa's Avatar
Mass Air Flow could also be the problem. My Max was having your exact same problem several weeks ago. I changed the KS and MAF. Works much better, but I am currently experience lower than normal idling due to EGR valve.
Old Oct 11, 2005 | 07:01 PM
PTownMax's Avatar
I still miss the max
coolant temp sensor (there are two) the one that goes to ecu (believe it's the front one)
i've been there and had the exact same problem
Old Oct 11, 2005 | 07:38 PM
ImmaSquashYou's Avatar
if you need to rev the car in order for it to keep on running, don't think its stupid, but do you have enough engine oil in yoru car? i believe the car has a safety switch that if its running on too lil oil, it would want to shut off. The coolant temp sensor controls how much coolant your engine is getting. if it is bad, you will be able to tell by the temp guage. If it is hot, that means its stuck closed, if its cold, that means its stuck open. This temp sensor i'm talking about is the one that is connected to the radiator not the one to the ecu.
Old Oct 11, 2005 | 08:44 PM
NCSUpilot's Avatar
YUP! I had the same problem also, and this is what it ended up fixing it...about $25 for the part and oh 5 minutes to change out...have the new one ready to go to minimize coolant loss. (You shouldn't lose more than a few ounces, if that).
Old Oct 11, 2005 | 09:19 PM
cefiro a32's Avatar
Thanks alot everyone. Ill try changing the coolant temp sensor, and see if that does it.
Does anyone have a pic of the sensor?
Old Oct 11, 2005 | 09:48 PM
NmexMAX's Avatar
dot dot dot ...
Wait for a code ...
Old Oct 11, 2005 | 09:56 PM
dabooki's Avatar
i had a similiar problem, but it was only once in a while stalling at stops and occaisional bogging down like it wanted to stall while driving constant speed.. i had ks sensor and coolant temp sensor codes, replaced and all is well. i only had a few trickles of coolant come out when i replaced mine. just make sure its cold
Old Oct 12, 2005 | 10:32 PM
cefiro a32's Avatar
Just changed the coolant temp this morning. I drove the car for about 10 miles without any problems.
Old Oct 12, 2005 | 10:44 PM
NLK's Avatar
NLK
Congrats! Hope thats the fix for it.
Old Oct 12, 2005 | 10:49 PM
cefiro a32's Avatar
Thanks NLK
Old Oct 13, 2005 | 12:58 PM
cefiro a32's Avatar
Car is shut off on me once again.
Old Oct 13, 2005 | 01:36 PM
THEJEFFERATOR's Avatar
do all the cheap, easy stuff first... f.i. cleaner, pcv, check for vac. leaks, sticking or poorly seating egr, maf plug connection, dirty maf screen (do not touch or spray wire inside !!!) dirty tb,
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Costa068
Aug 17, 2015 02:13 PM
kirkhilles
Aug 8, 2015 10:53 AM
erniel
Aug 8, 2015 09:32 AM
