Tracks to the right...
Old Oct 11, 2005 | 06:19 PM
Governor's Avatar
Had the tires on my 89 rotated and on the way home I notice the car now tracks to the right when you let go of the wheel? Tires only have 4000 miles on them and four wheel allignment was done at purchase I also replaced tie rod ends..struts..lower control arms and ball joints at this time also.. What could be causing this?
Car ran straight and true until rotation was done.
Old Oct 11, 2005 | 06:26 PM
Greeny's Avatar
¯\(°_o)/¯
Check your front tire pressure..If they are equal then switch the two front tires around and see if that helps...
Old Oct 11, 2005 | 06:31 PM
Governor's Avatar
Tire pressure equal..what will switching them prove?
Old Oct 11, 2005 | 06:42 PM
Greeny's Avatar
¯\(°_o)/¯
I have had the same problem after a tire rotation and swithing the fronts around fixed the problem....couldn't hurt...and it's freeeee ....$$$$$$
Old Oct 11, 2005 | 06:49 PM
Governor's Avatar
Ok I will try that..thanks
Old Oct 12, 2005 | 06:32 AM
tripleGmax's Avatar
was the road crested? that will cause it too.
Old Oct 12, 2005 | 04:16 PM
Governor's Avatar
I had my doubts but that did the trick...straight and true after switching front tires...thanks Greenmax
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
