Installed Tokico blues, car sits higher WTF!
Gents,
'96 GLE: Supplied the dealer with a full set of Tok blues and had a 4-wheel alignment last week. The car seems to sit higher. Didn't think struts would alter height. Is this an illusion or do the springs need to settle? Thanks...
Sometimes when I jack my car up it sits higher for a little while. But then again seeing all these slammed maxs with no wheel gap on here can make anything look like a 4x4. Also blown struts will make the car sit lower because it is no longer supporting as much vehicle weight.
Originally Posted by tucker
Gents,
If your didnt change the springs, the car isnt going to sit any lower...its probably sitting the same height it did with the stock stuff on because it seems like all you changed were the struts
-matt
-matt
If your old struts were blown, then you'll definitely notice the car sitting higher with the new ones.
Also, the Tokico Blues will be a little firmer than OEM to be able to cope at least somewhat with aftermarket springs, so they're probably supporting the springs a little more than the OEM ones did.
GLE springs are SUPER-soft... you'll notice differences among struts a lot more because of that.
If your old struts were blown, then you'll definitely notice the car sitting higher with the new ones.Also, the Tokico Blues will be a little firmer than OEM to be able to cope at least somewhat with aftermarket springs, so they're probably supporting the springs a little more than the OEM ones did.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
