Waiting for "I-Bent-My-Key-Day"
We've had a ton of rain the past week or so. Now it's tough to turn the lock with my key, I just know eventually it's gonna end up bending/breaking off if I can't get that lock to turn more easily. What are the odds that some WD-40 sprayed in the lock will relieve this, or am I gonna have to take off that whole door panel?
I just changed my speakers 2 days ago and dont like how you gotta take the whole door panel off just to do that, thats something i like about my old honda.
...What are the odds that some WD-40 ...
As mr coulombian rightly suggested, easier todo than ask.
just go to a car parts store and get the stuff thats ment for it. Its liquid graphite (very slippery stuff) and made for locks. My mazda was already tough to turn just last week and it was still 70-80 here, and that stuff made it easy again. I went ahead and put some in my max as preemtive matience.
~Alex
PS- What made me get the graphite stuff is my 1 month old key was cracking already from the lock. So the lock was really tough, now its as smooth as butter
~Alex
ive actually heard that a little liquid graphite squezed in to the lock does wonders. not sure where to get it. you just gotta pull that guard out of the way with a paper clip or something.
beat me to it
beat me to it
Recipe for Tarzan's redneck liquid graphite (tm): buy a pensil (buck a dozen), scrape graphite powder into a yogurt can with a knife, mix with WD-40, apply to your key and open/close lock, repeat several times.
liquid graphite like Alex_V and some others said. i was locked out of my car for about 6 hours to both doors and i called a friend who brought some over....its money.
edit: while you are out, get a copy of the key if you dont have one. worth the $1
Originally Posted by MyGreenMax94
This stuff works good for locks and lots of other stuff too....you can get it at idiotzone....
Anyway, I think I might be buying some of that liquid stuff alex mentioned, sounds like a handy tube to have
This stuff works good...
Lithium grease spray is wonder stuff. Bad side: Its wonder ingredient dries/vaporizes out in '12 months'...
Whatever u use, look ingredients: not alcohol.
Originally Posted by Wiking
Also In Sauna?
don't use wd-40 on your mechanisms.....you'll have a great intially result but then it'll eventually attract and hold on to more dirt and debris.
as was already mentioned, liquid graphite is the best stuff out there for tight mechanisms like your door lock. it may take some time to work it into all the nooks and crannies but worth it and it won't do more harm than good in the long run
c'mon guys...at least give him the CORRECT solution.
use WD40 in the lock...spray it in..and i mean drown it. WD = WATER DISPLACEMENT
ok once that's nice and wet get a rag and mop up the mess. feel free to work your key in there a few time and spray some more WD40. this will loosen all the pins up and wash out the crud in there.
now that it's totally water free get the lock ease. it's liquid graphite lube...what happens is that the liquid will carry the graphite and then it'll dry out and leave a nice film of graphite in the key hole. so once that's dry your key hole should be trouble free.
lithium grease is great...but everytime you pull your key out you have a very greasy key on your hands. people usually put keys in their pockets.
Originally Posted by staticlag
WD-40 dissolves greases. I dont suggest using it, unless you want to carry around a can of WD-40 with you forever.
Liquid graphite? Just buy some permatex "antiseize" it is the same thing. Buy it at autozone.
I did get some kinda lock stuff from autozone, apparently it also deices. Which pays for itself, with the frozen tundra that is southeast Virginia....
that being said, a couple of squirts, all was well. Which reminds me of another story....
Originally Posted by DanNY
antisieze is a high temp grease mixed with copper powder. if you want to mess up your lock this is the way to do it.
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Temperature range: -60°F to 1600°F. Salt, corrosion and moisture resistant - ideal for marine use. Non-aerosol version meets Mil Spec #907E. Level 3
Oh, and its good for bolts too.
I use antiseize for everything.. Pickle jar stuck? Dab o antiseize. Paint can stuck? Dab o antiseize. Lips chapped? Dab o antiseize.
