Waiting for "I-Bent-My-Key-Day"
Old Oct 12, 2005 | 11:10 AM
thajones's Avatar
We've had a ton of rain the past week or so. Now it's tough to turn the lock with my key, I just know eventually it's gonna end up bending/breaking off if I can't get that lock to turn more easily. What are the odds that some WD-40 sprayed in the lock will relieve this, or am I gonna have to take off that whole door panel?
Old Oct 12, 2005 | 11:14 AM
ColombianMax's Avatar
hmm, why dont you just give it a try with DW-40 and if it doesnt work then take the door panel off, its not that bad, the only ***** is taking out the handles that you lift to open the door.
I just changed my speakers 2 days ago and dont like how you gotta take the whole door panel off just to do that, thats something i like about my old honda.
Old Oct 12, 2005 | 11:51 AM
Wiking's Avatar
...What are the odds that some WD-40 ...
Succes rate probably 95% - only after/if u hit the keyhole. The lock mech itself lubr means panel mostly off, at the least handle...
As mr coulombian rightly suggested, easier todo than ask.
Old Oct 12, 2005 | 11:58 AM
Alex_V
just go to a car parts store and get the stuff thats ment for it. Its liquid graphite (very slippery stuff) and made for locks. My mazda was already tough to turn just last week and it was still 70-80 here, and that stuff made it easy again. I went ahead and put some in my max as preemtive matience.
~Alex
PS- What made me get the graphite stuff is my 1 month old key was cracking already from the lock. So the lock was really tough, now its as smooth as butter
Old Oct 12, 2005 | 11:59 AM
ozzombie13's Avatar
I will eat your children
ive actually heard that a little liquid graphite squezed in to the lock does wonders. not sure where to get it. you just gotta pull that guard out of the way with a paper clip or something.
beat me to it
Old Oct 12, 2005 | 12:31 PM
Tarzan's Avatar
Recipe for Tarzan's redneck liquid graphite (tm): buy a pensil (buck a dozen), scrape graphite powder into a yogurt can with a knife, mix with WD-40, apply to your key and open/close lock, repeat several times.
Old Oct 12, 2005 | 12:59 PM
internetautomar's Avatar
mod or sell?
i'd rather buy a $1 bottle of lock-ease
Old Oct 12, 2005 | 01:51 PM
staticlag's Avatar
WD-40 dissolves greases. I dont suggest using it, unless you want to carry around a can of WD-40 with you forever.
Liquid graphite? Just buy some permatex "antiseize" it is the same thing. Buy it at autozone.
Old Oct 12, 2005 | 02:02 PM
falseicon's Avatar
I like that recipe. Find a locksmith/key store, they're still around; liquid graphite in a handy tube $4
Old Oct 12, 2005 | 02:14 PM
tripleGmax's Avatar
liquid graphite like Alex_V and some others said. i was locked out of my car for about 6 hours to both doors and i called a friend who brought some over....its money.
edit: while you are out, get a copy of the key if you dont have one. worth the $1
Old Oct 12, 2005 | 02:29 PM
Greeny's Avatar
¯\(°_o)/¯
This stuff works good for locks and lots of other stuff too....you can get it at idiotzone....
Old Oct 13, 2005 | 01:34 AM
Its funny cuz autozone is like Ricerzone by my house. Nothing but Fast and the Furious wannabes, I'm including my friend he's a moron.
Anyway, I think I might be buying some of that liquid stuff alex mentioned, sounds like a handy tube to have
Old Oct 13, 2005 | 01:51 AM
Wiking's Avatar
This stuff works good...
Also In Sauna?
Lithium grease spray is wonder stuff. Bad side: Its wonder ingredient dries/vaporizes out in '12 months'...
Whatever u use, look ingredients: not alcohol.
Old Oct 13, 2005 | 02:00 AM
Originally Posted by Wiking
Also In Sauna?
If it smells like gas, its coming home with me and spraying it all over the bed
Old Oct 13, 2005 | 10:57 AM
DaWifey's90's Avatar
what can my max do for me
don't use wd-40 on your mechanisms.....you'll have a great intially result but then it'll eventually attract and hold on to more dirt and debris.
as was already mentioned, liquid graphite is the best stuff out there for tight mechanisms like your door lock. it may take some time to work it into all the nooks and crannies but worth it and it won't do more harm than good in the long run
Old Oct 13, 2005 | 11:25 AM
DanNY's Avatar
Ad·min·is·tra·tor
c'mon guys...at least give him the CORRECT solution.
use WD40 in the lock...spray it in..and i mean drown it. WD = WATER DISPLACEMENT
ok once that's nice and wet get a rag and mop up the mess. feel free to work your key in there a few time and spray some more WD40. this will loosen all the pins up and wash out the crud in there.
now that it's totally water free get the lock ease. it's liquid graphite lube...what happens is that the liquid will carry the graphite and then it'll dry out and leave a nice film of graphite in the key hole. so once that's dry your key hole should be trouble free.
lithium grease is great...but everytime you pull your key out you have a very greasy key on your hands. people usually put keys in their pockets.
Old Oct 13, 2005 | 11:27 AM
DanNY's Avatar
Ad·min·is·tra·tor
antisieze is a high temp grease mixed with copper powder. if you want to mess up your lock this is the way to do it.
Old Oct 13, 2005 | 01:23 PM
CyMax's Avatar
I concure.
Old Oct 14, 2005 | 07:23 AM
thajones's Avatar
I did get some kinda lock stuff from autozone, apparently it also deices. Which pays for itself, with the frozen tundra that is southeast Virginia....
that being said, a couple of squirts, all was well. Which reminds me of another story....
Old Oct 14, 2005 | 07:40 AM
xbubbax's Avatar
lithium grease, or lock seize....somthing like that. you could use lock deicer.....or wd40 to loose things up, then the grease.
Old Oct 14, 2005 | 11:18 AM
staticlag's Avatar
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Temperature range: -60°F to 1600°F. Salt, corrosion and moisture resistant - ideal for marine use. Non-aerosol version meets Mil Spec #907E. Level 3
I use antiseize for everything.. Pickle jar stuck? Dab o antiseize. Paint can stuck? Dab o antiseize. Lips chapped? Dab o antiseize.
Oh, and its good for bolts too.
Old Oct 14, 2005 | 11:40 AM
ROTFLMFAO!!!
MaxiNoob98
Oct 2, 2015 10:13 PM
Spartan1310
Sep 28, 2015 08:03 AM
REDinLV
Sep 28, 2015 12:31 AM
