AC system removal
AC system removal
I was wondering if there is anyway i could releave the presser in the AC system so i could remove it from the car completly. I have the motor out and i came up with a late idea to take it out for a small improvment in hp and weight reduction. i know i should of done this before when i could drive the car to a place and have them do it, but its to late. any ideas?
Originally Posted by madmaxima420
the whole system work with no problems, pm an offer
Just releasing the refrigerant into the atmosphere is easy. Just unscrew one of the refrigerant lines until it starts to leak.
as long as it's not R12, releasing it to the atmosphere is not a problem. R134 is only $10/can at autozone. I think it would be more trouble than it's worth to try to capture it instead of releasing it.
be sure to unscrew a low pressure line and NOT a high pressure line. It could burst and injure you.
http://www.epa.gov/ozone/title6/608/subrecsm.html
"Under section 608 of the Clean Air Act, it has been illegal since November 15, 1995, to knowingly vent substitutes for CFC and HCFC refrigerants during the maintenance, service, repair and disposal of air-conditioning and refrigeration equipment. On June 11, 1998, EPA proposed a regulation to fully implement this statutory venting prohibition."
Don't be a feakin idiot about it, just have it evacuated like you're supposed to.
This is just rediculous. I don't see anything wrong with venting r134a. I wouldn't vent R12 though.
The EPA in a lot of cases is full of $hit. Note that " heat transfer fluids are considered refrigerants."
"EPA is proposing to exempt the following refrigerants from the venting prohibition:"
* ammonia that is used in absorption systems or in commercial or industrial process refrigeration systems
* hydrocarbons that are used in industrial process refrigeration systems for processing hydrocarbons
* chlorine that is used in industrial process refrigeration systems for processing chlorine or chlorine compounds
* CO2, nitrogen, and water
So, venting water or ammonia (windex) to the atmosphere is currently illegal. Breathing is illegal too since we exhale CO2. Venting motor oil is illegal too since it's a heat transfer fluid.
If you car is still going to be a street car, then y in the heck do u want to take the ac off, do u know how little power it takes...... even if u have the ac on full blast and you go to WOT the ac cluth will automaticaly disengage. so u would loose the hp it take to move the pully while it is freewheeling............-.0001 hp
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
